Back Pedal & Clutch Slip
ehfour
22
13
Vancouver
hey guys/gals- picked up a Relay and had 2 questions
1) Any concerns with back pedaling the motor? IE: when going to Lube the chain on the ground, if I were to stick an allen key in the chainring spider to lock out the motor freehub. I didn't see anything in the Fazua website
2) Has anyone else felt a slip or engagement step, when pedaling from a stand still? Regardless of power mode and only on the left side
Al-ec
36
63
West Wales
1) Tend to use a bike stand or re-usable strap around the pedal and chain ring. No problems so far back-pedalling to clean/lube.
2) No but I'm on a fairly new bike. Assume the crank is properly nipped up tight / on correctly. Only left side sounds more like a crank issue to me but I'm relatively new to eMTBs, old hand at home fettling MTBs though.
525K
