Avinox M2s rattle
The noise generated in that video is 100% going to appear on all motors to some degree, that is simply backlash in the gear sets which cannot be removed without removing all tolerances from the gears and having a gearset which wont turn. The reason some people hear it after a few rides is the grease gets distributed and no doubt when the motor warms up the tolerances increase to some extent. You are totally wasting your time chasing that backlash sound, even if you get a new motor that will do it also after a time. It is 10x quieter than the M1 and the m2 doesn't do it on every bump, but its not a fault - would be nice if it was totally 100% silent but not possible to remove all backlash with that design.
With a working solution which eliminates gear backlash, this should not happen.
This is from Avinox website, motor being quiet by eliminating backlash is one of their selling points:
Refined Design, Quiet Operation​
Avinox uses high-strength, high-toughness polymer materials to effectively suppress noise when the gearbox operates at high speed. Additionally, the new-generation Avinox M2S features a dual-meshing gear design that eliminates gear backlash, reducing pedal kickback noise and ensuring a quiet ride.
Indeed, but as it says… ‘reducing’ pedal kickback noise… not removing kickback noise…
Then you should have this kickback noise from new, not after you ride it for several 100's miles ...
It will be a mass produced motor in a factory where during assembly a big glob of grease will applied over the gears, that will distribute and thin down slightly after some miles.
