I want to put a rear rack on my Amflo Carbon PL. I bought a nice one for suspension bikes but my bike dealer said don t do it . ?? I want to bring a 6 pack and extra clothes to the woods
Welcome aboard,
@Bad Daddy - and straight in with the important stuff: beer logistics. Respect.
Your dealer's not being a killjoy, mind. The issue is that the
Amflow PR Carbon is a full-suspension carbon frame with 150mm of rear travel, and a standard seatpost- or seatstay-mounted rack has nowhere safe to bolt to. The rear triangle is moving through its travel constantly, so anything clamped across it either fouls the tyre as the suspension compresses, or puts load into a carbon stay that was never designed to carry it. Carbon doesn't dent as a warning like alloy does - it just cracks. That's the "don't do it."
A few ways to still get your six-pack to the woods: •
Seatpost-clamp rack (the type that grips the post, not the frame) - these are made for full-sus bikes and don't touch the rear triangle. Just watch the weight limit; most are rated around 9 - 10kg, and check it clears the tyre at full droop. A dropper post complicates the mounting too, so measure carefully.
A decent backpack or hip pack - honestly the path of least resistance for beer-and-a-spare-layer. No rattle, no clearance faff. •
Frame/rear-triangle bags designed for full-sus bikes - smaller capacity, but zero risk to the frame.
The rack you already bought "for suspension bikes" might well be the seatpost-clamp type - if so, you may be fine. If it bolts to the stays or the axle, that's the one to keep off the Amflow. Tell us how it mounts (or post a photo) and we'll give you a straight yes/no.
Enjoy the evening ride - perfect weather for it.
