Sold 2024 Specialized Levo Sl Sl2 Sworks Limited Ltd Carbon Flight Attendant S3: £6200
Mark24
Bursledon
Bike / Product Year: 2024
Manufacturer: Specialized
Model: Levo Sl Sl2 Sworks Limited Ltd Carbon Flight Attendant
Size S3
Asking Price: £6200
Location Southampton
Description
S-Works Turbo Levo SL LTD​
Bike is brand new never used​
Size S3​
This is a very high spec bike​
Motor
Specialized 1.2 SL Custom RX Trail Tuned Motor, 50Nm power, 320W power
Battery
Specialized SL1-320, fully integrated, 320Wh
UI/Remote
Specialized MasterMind TCU, percentage of remaining charge, 120 possible display configurations, MicroTune assist adjustment, ANT+/Bluetooth®, w/Handlebar remote
Charger
Custom charger, 48V System w/ SL system charger plug
Wiring Harness
Custom Specialized wiring harness
Frameset
Frame
All new Levo SL SW Frame, Fact 11m carbon, carbon shock extension, 150mm travel, adjustable head angle, BB height, and compatible with 27.5 or 29" wheels.
Seat Binder
Alloy, 38.6mm
Suspension
Rear Shock
Rockshox Flight Attendant SuperDeluxe Ultimate, 210x55
Fork
All New Lyrik Ultimate Flight Attendant, 29", 160mm of travel, wirelessly controlled damping, 44mm offset
Brakes
Front Brake
SRAM Code Stealth Ultimate, 4-piston caliper, hydraulic disc, 200mm
Rear Brake
Drivetrain
Shift Levers
SRAM AXS POD Controller
Rear Derailleur
SRAM XX Eagle Transmission Derailleur
Cassette
SRAM XX Eagle Transmission Cassette, 12spd, 10-52t
Chain
SRAM XX Eagle Transmission Flattop Chain
Crankset
SRAM Carbon Crankset, Dub interface
Chainrings
New SL 1.2 spider, 104BCD w/SRAM 32t Transmission compatible alloy ring
Wheels & Tires
Rear Wheel
Roval Traverse SL 27.5, 148mm spacing, XD freehub body
Front Tire
Butcher, GRID TRAIL casing, GRIPTON® T9 compound, 2Bliss Ready, 29x2.3"
Front Wheel
Roval Traverse SL 29
Rear Tire
Eliminator, GRID TRAIL casing, GRIPTON® T7 compound, 2Bliss Ready, 27.5 x 2.3"
Inner Tubes
Standard, Presta Valve
Cockpit
Stem
Deity, 35.0mm
Handlebars
Roval Traverse SL Carbon, riser bar, 6-degree upsweep, 8-degree backsweep, 30mm rise, 780mm, 35.0mm
Grips
Deity Grips
Saddle
Bridge, 155/143mm, Hollow Ti-rails
SeatPost
RockShox Reverb AXS, 30.9, 1X remote, (S1:100mm, S2: 125mm, S3: 150mm, S4-S6: 170mm)
Accessories
SWAT
SWAT CC steerer tube integrated tool with chain tool and link
Size S3
Asking Price: £6200
Description
Size S3​
Motor
Battery
UI/Remote
Charger
Wiring Harness
Frameset
Frame
Seat Binder
Alloy, 38.6mm
Suspension
Rear Shock
Fork
Brakes
Front Brake
Rear Brake
Drivetrain
Shift Levers
Rear Derailleur
Cassette
Chain
Crankset
Chainrings
Wheels & Tires
Rear Wheel
Front Tire
Front Wheel
Rear Tire
Inner Tubes
Cockpit
Stem
Deity, 35.0mm
Handlebars
Grips
Deity Grips
Saddle
SeatPost
Accessories
SWAT
Hi, would you be interested in swapping the frameset and drivetrain for a Brand new Scott Spark ST910.
Cheers
    676K
