crazyknowledge
Description
Used once, as new condition completely unmarked total retail price of £435 !!
31.6mm diameter, 125mm drop
RRP £55 Wolf Tooth Dropper Lever, mounts directly to Sram brakes or can be used with the band clamp provided.
RRP £380 Wolf Tooth Resolve Dropper Seat post, 31.6mm, 125mm drop, used once completely as new and unmarked.
The new Wolf Tooth Resolve™ Dropper Post not only offers a best-in-class stack height it's also the very first on the market to include a self-bleeding cartridge. Now dropper post squish is a thing of the past!
If you want extra peace of mind and stability when facing steep downhills or obstacle-laden trails this dropper post is for you. Designed to be both reliable and easily serviceable the Resolve Technology cartridge purges air every time the seatpost is fully dropped so that you'll never have to bleed it manually.
Available in two diameters and three travel lengths the dropper post not only has an extremely low stack height of just 32mm lower than any other dropper post currently available but also a short insertion depth which means a longer travel post can be fitted into your frame.
Built to last exceeding ISO 4210 standards and featuring a patent-pending air filter which helps ensure smoother operation and prolong its life by keeping the internals clean the dropper post has a two-bolt saddle clamp and is compatible with both round and oval saddle rails.
The Resolve™ Dropper Post comes with a cable and housing as standard with the option to separately purchase a ReMote Dropper Lever to encourage smooth operation and internal spacers to allow micro travel adjustments in 5mm increments up to a maximum of 35mm reduction in travel.
Light and strong complete with exquisitely CNC machined components it will let you optimise your travel length for maximum confidence and comfort whether you're riding uphill downhill or along winding singletrack.
100% serviceable, you can be sure that it'll be around to offer precise travel adjustment during trail rides and enduro races for many years to come.
Key features:
The only dropper post on the market with a self-bleeding cartridge
Exceptionally low stack height of 32mm allowing better control
Patent pending air filter keeps internal clean
Reliable operation with 2-bolt saddle clamp
100% serviceable video tutorials available
31.6mm
125mm
Starting weight 440g
Compatible with round or oval saddle rails
Replacement parts available through Wolf Tooth's “Right to Repair” scheme
Can be easily registered for warranty by scanning the unique QR code
Designed engineered and assembled at Wolf Tooth's Minnesota HQ
Bike / Product Year: 2023
Manufacturer Wool Tooth
Model Resolve Dropper Post
Asking Price £145
Location Surrey UK
Description
Key features:
31.6mm
125mm
Key features:
31.6mm
125mm
Asking Price £145
Location Surrey UK
Description
Key features:
31.6mm
125mm
