For Sale (BIKE) 2022 Specialized Turbo Levo S-Works Hybrid $8999.00
EMTB!
Eagle, Idaho
I'm selling a hybrid of sorts Levo 3 S-Works/ Levo Carbon Comp w/ the original S-Works Fox X2 Factory Kashima and Fox 38 Factory Kashima 160mm size S5. The frame has 675 miles currently and won't be ridden again. The goal is to move the bike at a great price point and on to my next build. See specs below for the current build up.
To clarify, everything is new except the frame, fork and shock, but they are in excellent condition regardless. Buyer to cover any payment fees if applicable and shipping- would prefer local pick up. Message with questions.
S-Works parts taken off before a first ride that are still brand new are carbon bars, Deity stem, Deity grips, saddle and carbon crank arms. Fork and shock have around 150 miles and were swapped out for RockShox dampers until I retired the bike and swapped the Fox stuff back on.
Full Spec:
COCKPIT
Stem
Deity, 35.0mm
Saddle
Bridge Comp, Hollow Cr-mo rails, 155/143mm
Grips
Deity, Knuckleduster, Black
Handlebars
Roval Traverse SL Carbon, riser bar, 6-degree upsweep, 8-degree backsweep, 30mm rise, 780mm, 35.0mm
SeatPost
X-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SLR LE lever, 34.9, 175mm
FRAMESET
Seat Binder
Alloy, 38.6mm
Frame
FACT 11m full carbon, 29" front wheel, 27.5" rear wheel, full internal cable routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel, geo adjust head tube, geo adjust horst pivot
Fork
FOX FLOAT 38 Factory 29, Grip2 damper, 44mm offset, HSC, LSC, HSR, LSR, 110x15mm, 1.5" tapered steerer, 160mm travel, Kashima
WHEELS
Rear Hub
Alloy, sealed cartridge bearings, 148mmx12mm thru-axle, 28h
Front Hub
Alloy, sealed cartridge bearings, 15x110mm thru-axle, 28h
Front Tire
Butcher, GRID TRAIL casing, GRIPTON® T9 compound, 2Bliss Ready, 29x2.6"
Spokes
DT Swiss Industry
Rear Tire
Eliminator, GRID TRAIL casing, GRIPTON® T7 compound, 2Bliss Ready, 27.5x2.6"
Rims
Specialized 29, hookless alloy, 30mm inner width, tubeless ready
Inner Tubes
Standard, Presta Valve
E-BIKE
Wiring Harness
Custom Specialized wiring harness
Charger
Custom charger, 42V4A w/ Rosenberger plug, 100-240V
Motor
Specialized 2.2 Custom Rx Trail Tuned Motor
Battery
Specialized M3-700, Integrated battery, 700Wh
UI/Remote
Specialized MasterMind TCU, percentage of remaining charge, 120 possible display configurations, MicroTune assist adjustment, over-the-air updates, ANT+/Bluetooth®, w/Handlebar remote
SUSPENSION
Rear Shock
FOX FLOAT X2 Factory, HSC,LSC, and HSR,LSR, 2-position lever, 55x210mm, Kashima
DRIVETRAIN
Crankset
Praxis Carbon M30, custom offset, 160mm
Shift Levers
SRAM GX, trigger, 12-speed
Rear Derailleur
SRAM GX Eagle, 12-speed
Chain
SRAM NX Eagle, 12-speed
Chainrings
SRAM X-Sync Eagle, 104 BCD, 34t, steel
Cassette
Sram XG-1275, 12-speed, 10-52t
BRAKES
Rear Brake
SRAM Code RS, 4-piston caliper, hydraulic disc, 200mm
Front Brake
SRAM Code RS, 4-piston caliper, hydraulic disc, S/M: 200mm, L/XL: 220mm
    676K
