For Sale (BIKE) 2021 Mondraker Level R XL: £5000
yorkshire89
468
661
North Yorkshire
Bike / Product Year: 2021
Manufacturer: Mondraker
Model: Level R
Size XL
Asking Price: £5000
Location Tadcaster
Description Mondraker Level R 2021 XL Ebike
Mondraker Level R 2021 in extra large.
I purchased this bike new in September 2020 (receipt included with sale).
Bike has only had a couple of months use and is in very good condition overall.
I've had the frame, forks and cranks professionally fitted with frame protection from new.
I've had the motor replaced under warranty after an issue, it has 0 miles shown on the odometer - new motor comes with 2 years warranty from 31.08.21 (receipt included).
There is a small chip in the paint under the seatpost (pictured) that it had from new.
There is also a scratch on the chainstay from the incorrect cranks fitted from factory, and a minor scratch to the frame protection tape under the downtube from a rock strike.
I've had replacement cranks fitted and have a brand new chainstay in the same colour that will be included in the sale.
I haven't bothered to fit this since the scratch is very minor.
Spec is as standard, for the asking price I will also include a Rockshox Reverb Stealth dropper seatpost and pair of nearly new Michelin E-Wild front and rear tyres.
PRODUCT DESCRIPTION
2021 LEVEL R 29″ E-BIKE
The Level takes e-MTB riding to another level. Introducing 29″ wheels and long travel to achieve high performance, hardcore enduro riding. Pairing a 180mm fork with 170mm of coil sprung Zero link rear suspension, the Level features pioneering Forward Geometry and is powered by the Bosch Performance Line CX G4 system w/Intube PowerTube 625Wh Bosch battery with a Kiox On Board computer.
The Level R features a Fox 38 FIT GRIP Perfroamcne 180mm fork, Fox DHX2 225x75mm Trunnion shock, DT Swiss H1900 Hybrid ebike wheelset and SRAM Code R 4-pot brakes.
SPECIFICATION
FRAMELEVEL 6061 ALLOY STEALTH EVO, E-BIKE OPTIMIZED ZERO SUSPENSION SYSTEM, 170MM TRAVEL, FORWARD GEOMETRY, INTERNAL REMOVABLE BATTERY WITH INTEGRATED ALLOY COVER, BOOST 12X148MM REAR AXLE, TAPERED HEAD TUBE, ONE-PIECE MONOBLOCK UPPER LINK, HHG INTERNAL CABLE ROUTING, MAX CAPACITY SEALED BEARINGS, OVERSIZE 17MM AXLES, INTEGRATED DROPOUT SPEED SENSOR, EXCLUSIVE PLASTIC MOTOR COVERS
SIZESS: 380MM / M: 420MM / L: 450MM / XL: 490MM
REAR SHOCKFOX DHX2 PERFORMANCE ELITE, 225X75MM. SETTINGS: LOW-SPEED COMPRESSION, LOW-SPEED REBOUND, SPRING PRELOAD. TRUNNION TOP MOUNT, 25X10MM BOTTOM BUSHINGS
SHOCK SETTINGSMEDIUM COMPRESSION, MEDIUM REBOUND. SPRING RATE: S/M SIZE 300 LBS, L SIZE 350 LBS, XL SIZE 400 LBS
FORKFOX 38 29 FLOAT FIT GRIP EVOL PERFORMANCE, 180MM, E-BIKE TUNED, TAPERED STEERER TUBE, BOOST 15X110MM AXLE, 44MM OFFSET. SETTINGS: 3 POSITIONS WITH MICRO ADJUST COMPRESSION, LOW-SPEED REBOUND, AIR PRELOAD
HEADSETONOFF SATURN TAPERED FOR 1-1/8″ TO 1-1/2″ HEAD TUBE, ACB SEALED BEARINGS, TOP 41X30.2X7X45°X45°, BOTTOM 51.9X40X8X45°X45°
STEMONOFF SULFUR FG 30MM 0°, 6061 FORGED ALLOY, 31.8MM BARBORE
HANDLEBARONOFF SULFUR 1.0 DOUBLE BUTTED 6061 ALLOY, RISE: 20MM, WIDTH: 780MM, 9° BACKSWEEP, 5° UPSWEEP, 31.8MM BARBORE
GRIPSONOFF DESERT, 1LOCK-ON, 135MM, SIZES: S/M L/XL
SEATPOSTONOFF PIJA DROPPER INTERNAL, DIAMETER 31.6MM, S SIZE: 387X125MM, M SIZE: 425X150MM, L/XL SIZE: 465X170MM
SADDLESDG BEL-AIR 3.0, EVA FOAM, STEEL RAILS
FRONT BRAKESRAM CODE R, OVERSIZED 4-PISTON CALIPER, CENTERLINE 220MM IS 6 BOLTS ONE-PIECE ROTOR, STEEL-BACKED METAL SINTERED PADS
REAR BRAKESRAM CODE R, OVERSIZED 4-PISTON CALIPER, CENTERLINE 200MM IS 6 BOLTS ONE-PIECE ROTOR, STEEL-BACKED METAL SINTERED PADS
BRAKE LEVERSRAM CODE R, TOOL-FREE REACH ADJUST
RIMSDT SWISS H1900 SPLINE 29, 30MM INTERNAL WIDTH, SLEEVED ALUMINUM, TUBELESS READY, 28 SPOKES
SPOKESDT HYBRID SP, STRAIGHTPULL
FRONT HUBDT 370, BOOST 15X110MM, IS 6 BOLTS
REAR HUBDT 370, BOOST 12X148MM, 3 PAWL SYSTEM, IS 6 BOLTS
FRONT TYREMAXXIS ASSEGAI 29X2.5WT, TUBELESS READY, 3C MAXX GRIP COMPOUND, DH CASING, 60X2TPI, FOLDING BEAD
REAR TYREMAXXIS ASSEGAI 29X2.5WT, TUBELESS READY, 3C MAXX GRIP COMPOUND, DH CASING, 60X2TPI, FOLDING BEAD
CRANKSETE.13 E*SPEC PLUS EBIKE, 165MM
CHAINRINGSRAM X-SYNC 2 EAGLE 34T, STEEL, NARROW-WIDE, 104 BCD
BOTTOM BRACKET
PEDALS
CHAINSRAM SX EAGLE, 12S, POWERLOCK
FRONT DERRAILLEUR
REAR DERRAILLEURSRAM GX EAGLE, TYPE 3 ROLLER BEARING CLUTCH, CAGE LOCK, 1X12S, X-ACTUATION 1:1
SHIFT LEVERSSRAM TRIGGER NX EAGLE, 12S, X-ACTUATION 1:1, SINGLE CLICK
CASSETTESRAM PG-1210, 11-50T, 12S
MOTORBOSCH PERFORMANCE LINE CX CRUISE (25KM/H) GEN4
BATTERYBOSCH POWERTUBE 625WH
DISPLAYBOSCH KIOX
DERAILLEUR HANGERMONDRAKER M068
£5000, collection from Tadcaster
Elover
55
35
Chelmsford
Hi, just thought i would ask as i have a 2021 crafty. Did you de restrict as i have tried with a vol 3 and does not seem to work. Thanks if any ides?
