Sold 2021 Mondraker Crafty Carbon RR: £7250
Baileyjd
Midlands.
Bike / Product Year: 2021
Manufacturer: Mondraker
Model: Crafty Carbon RR
Asking Price: £7250
Location West Midlands
Description SIZE LARGE /490MM REACH
ONE OF THE LIGHTEST FULL FAT EMTBs OUT THERE.
PURCHASED OCT 2020 / HAVE ORIGINAL RECEIPT
RIDDEN A HANDFUL OF TIMES - 128 MILES
HAS MOST RECENT BOSCH UPDATE 3/2021
ALL ORIGINAL SPECIFICATIONS WITH THE EXCEPTION OF THE DROPPER /SWAPPED TO 125MM
IMMACULATE CONDITION
FRAMECRAFTY STEALTH AIR FULL CARBON, E-BIKE OPTIMIZED ZERO SUSPENSION SYSTEM, 150MM TRAVEL, FORWARD GEOMETRY, INTERNAL NON-REMOVABLE BATTERY, BOOST 12X148MM REAR AXLE,
REAR SHOCKFOX FLOAT DPS FACTORY KASHIMA, 205X65MM. SETTINGS: COMPRESSION 3 POSITIONS LEVER, LOW-SPEED COMPRESSION, LOW-SPEED REBOUND, AIR PRELOAD. TRUNNION TOP MOUNT, 25X10MM BOTTOM BUSHINGS
SHOCK SETTINGSMEDIUM COMPRESSION, MEDIUM REBOUND, 0.4 VOLUME SPACER
FORKFOX 36 29 FLOAT FIT4 EVOL FACTORY KASHIMA, 160MM, E-BIKE OPTIMIZED, TAPERED STEERER TUBE, BOOST 15X110MM AXLE, 44MM OFFSET, 68MM OD CROWN. SETTINGS: 3 POSITIONS WITH MICRO ADJUST COMPRESSION, LOW-SPEED REBOUND, AIR PRELOAD
HEADSETACROS CUSTOM FOR 1-1/2" HEAD TUBE, ANGULAR CONTACT BEARINGS 40X52X7, INTERNAL CABLE ROUTING
STEMONOFF KRYPTON FG 30MM, 6061 FORGED ALLOY, 31.8MM BARBORE
HANDLEBARONOFF KRYPTON CARBON 1.0, RISE: 25MM, WIDTH: 780MM, 9° BACKSWEEP, 5° UPSWEEP, 31.8MM BARBORE
GRIPSONOFF DESERT, 1LOCK-ON
SADDLEFIZIK ANTARES R7
FRONT BRAKESHIMANO XT M8120, 4 PISTON CALIPER, MT800 ICE-TECH 203MM CENTERLOCK ROTOR, RESIN PADS WITH FIN
REAR BRAKESHIMANO XT M8120, 4 PISTON CALIPER, MT810 ICE-TECH 203MM CENTERLOCK ROTOR, RESIN PADS WITH FIN
BRAKE LEVERSHIMANO XT M8100, ERGONOMIC ANTISKID LEVER WITH SERVO WAVE, TOOL LESS REACH ADJUST, FREE STROKE ADJUST
RIMSDT SWISS HX1501 SPLINE ONE 29, 30MM INTERNAL WIDTH, TUBELESS READY, 28 SPOKES
SPOKESDT HYBRID SP, STRAIGHTPULL
FRONT HUBDT 240, BOOST 15X110MM, CENTERLOCK\
REAR HUBDT 240, BOOST 12X148MM, 24T RATCHET SYSTEM, CENTERLOCK
FRONT TYREMAXXIS MINION DHF 29X2.6, TUBELESS READY, 3C MAXX TERRA, EXO+ PROTECTION, 120TPI, FOLDING BEAD
REAR TYREMAXXIS MINION DHR II 29X2.6, TUBELESS READY, 3C MAXX TERRA, EXO+ PROTECTION, 120TPI, FOLDING BEAD
CRANKSETE.13 TRS RACE CARBON EBIKE, 165M
CHAINRINGSHIMANO E8000 34T, STEEL, 104 BCD
CHAINSHIMANO XT M8100, 12S, QUICK-LINK
REAR DERRAILLEURSHIMANO XT M8100, SGS, SHADOW+, 12S
SHIFT LEVERSSHIMANO XT M8100, RAPID FIRE PLUS, 12S
CASSETTESHIMANO XT M8100 10-51T HYPERGLIDE+, 12S
MOTORBOSCH PERFORMANCE LINE CX CRUISE (25KM/H) GEN4
BATTERYBOSCH POWERTUBE 625W
DISPLAYBOSCH KIOX
    673K
