Sold 2020 Specialized Turbo Levo Comp: £4300ono
BFG
Brighton, UK
Bike / Product Year: 2020
Manufacturer: Specialized
Model: Turbo Levo Comp
Asking Price: £4300ono
Description: For sale: XL 2020 Specialized Turbo Levo Comp in black
  • I’m reluctantly selling my new Levo because it's basically too small for me. It's a great bike, but I need something bigger - I'd happily keep it if it was an XXL :(
  • I bought in November and only has 200ish miles on the clock. I’ve spoken to the shop (in Brighton) and they will continue to look after the bike for a new owner, I’m happy to transfer any warranty across
  • I’ve upgraded a few bits -
    • Renthal 800mm bar,
    • VP Harrier pedals
    • Blk Dmnd Butcher rear
    • Set it up tubeless
    • Front Mudhugger
    • (Photo shows carbon wheels with Maxxis, bit these have been swapped out)
  • The diagnostics are all fine, no funny noises or issues at all, it’s been perfect :)
  • List price is £5.5k, but I realise I'm going to take a hit on that.
  • I can take more pics for those interested
Specialized 2020 Turbo Levo Comp
FRAME
Specialized M5 Premium Aluminum, 29 Trail Geometry, integrated down tube battery, enclosed internal cable, Command Post routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel
FORK
RockShox Lyrik Select RC 29, DebonAir spring, Charger RC damper, 51mm offset, 15x110mm thru-axle
REAR SHOCK
RockShox Deluxe Select+ w/ custom air valve, 52.5x210mm
FRONT HUB
Specialized, sealed cartridge bearings, 15x110mm thru-axle, 28h
REAR HUB
Specialized, sealed cartridge bearings, 12x148mm thru-axle, 28h
SPOKES
DT Swiss Industry
RIMS
Roval Traverse 29, hookless alloy, 30mm inner width, tubeless ready
INNER TUBES
Standard, Presta valve
FRONT TYRE
Butcher, GRID casing, GRIPTON® compound, 2Bliss Ready, 29x2.6"
REAR TYRE
Eliminator, BLCK DMND Casing, 2Bliss Ready, 29x2.3"
CRANKSET
Praxis, 2D cold-forged alloy, custom offset, 165mm
CHAINRINGS
32T, custom steel
SHIFT LEVERS
SRAM S700, single-click lever
REAR DERAILLEUR
SRAM GX, long cage, 11-speed
CASSETTE
SRAM PG-1130, 11-speed, 11-42t
CHAIN
KMC X11ET, 11-speed w/ Missing Link™
FRONT BRAKE
SRAM Guide RE, 4-piston caliper, hydraulic disc, 200mm
REAR BRAKE
HANDLEBARS
Specialized Trail, 6061 alloy, 8-degree backsweep, 6-degree upsweep, 27mm rise, 780mm, 31.8mm clamp
GRIPS
Specialized Sip grip, half-waffle, S/M: regular thickness, L/XL: XL thickness
STEM
Specialized Trail, 3D-forged alloy, 4-bolt, 6-degree rise
SADDLE
Bridge 155 S2, Bridge 143 S3/S4/S5, Hollow cr-mo rails
SEATPOST
X-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SRL LE lever, 34.9mm, S: 125mm, M/L: 150mm, XL: 170mm
SEAT BINDER
Specialized bolt-type, alloy, 38.6mm
SWAT
Specialized Z-Cage w/EMT Cage Mount MTB Tool
MOTOR
Specialized 2.1, custom Rx Trail-tuned motor, 250W nominal
UI/REMOTE
Specialized TCU, 10-LED State of charge, 3-LED Ride Mode display, ANT+/Bluetooth®
BATTERY
Specialized M2-700, integrated battery w/rock guard, 700Wh
CHARGER
Custom charger, 42V4A w/ Rosenberger plug
WIRING HARNESS
Custom Specialized wiring harness
