Sold 2020 Specialized Levo Comp Alloy - Lyrik Ultimate - Magura MT7 Brakes: 4500.00
Celadonjoe
Horsham
Bike / Product Year: 2020
Manufacturer: Specialized
Model: Levo Comp Alloy - Lyrik Ultimate - Magura MT7 Brakes
Asking Price: 4500.00
Location West Sussex
Description Hi All,
This 2020 Levo Comp Alloy in extra large, storm grey bought in February is a great bike. It has the latest version of motor installed with the new software and the latest version 3 battery harness. The motor has done 249Km and the 700Wh battery has done 26 charge cycles.
The fork has been upgraded to a Lyrik Ultimate 170mm with a 44mm offset.
The bike has an Invisiframe kit fitted which has helped to protect the frame from most scuffs and scrapes however an experiment with a rear coil shock has left a scrape up the inside of the side arm. This is just cosmetic.
It comes with Hillbilly Black Diamond 29 x 2.6" tyres fitted back and front set up tubeless and also comes with the original Butcher Grid and Eliminator Black Diamond for when the weather gets better.
The rear shock has an upgraded MegNeg air can fitted that helps to increase the mid and end travel support. The original air can comes supplied too and if you are much over 14 stone you will need to run this rather than the MegNeg.
I will supply the original proof of purchase so you can get a warranty done if need be.
Please see the specification list below which has details on the condition of each component. Changes from the original spec are in bold:
FRAME: X Large Storm Grey Specialized M5 Premium Aluminum, 29 Trail Geometry, integrated down tube battery, enclosed internal cable, dropper post routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel - Small scratches and scrapes on the inside of the sidearm where a different rear shock scraped away the paint. Invisiframe kit which has some scuffs and scrapes but the paint underneath is in good condition.
REAR SHOCK: RockShox Deluxe Select+ w/ custom air valve, 52.5x210mm - With MegNeg Air Can fitted which increase mid and end stroke support. Also supplied with original air can. If you are much over 14 stone you will need to switch back to this.
FORK: RockShox Lyrik Ultimate 29, 170mm DebonAir spring C1, Charger 2.1 damper, 44mm offset, 15x110mm thru-axle - Used and in good condition
STEM: Specialized Trail, 3D-forged alloy, 4-bolt, 6-degree rise
HANDLEBARS: Specialized Trail, 6061 alloy, 8-degree backsweep, 6-degree upsweep, 27mm rise, 31.8mm clamp, XS 720mm, S-XL 750mm. - Unused but has a small scratch
GRIPS: Specialized Sip grip, half-waffle, S/M: regular thickness, L/XL: XL thickness - Brand new and unused.
FRONT BRAKE: Magura MT7, 4-piston caliper, hydraulic disc, 200mm Sram Centerline Rotor - Brake is brand new and unused. Rotor is original and used.
REAR BRAKE: Magura MT7, 4-piston caliper, hydraulic disc, 200mm Sram Centerline Rotor - Brake is brand new and unused. Rotor is original and in good condition.
REAR DERAILLEUR: SRAM GX, long cage, 11-speed - Original and in good condition.
SHIFT LEVERS: SRAM S700, single-click lever - Original and in good condition.
CHAIN: Sram XX1 11 Speed Chain - Fitted 3 rides ago and runs fine on the original cassette.
CRANKSET: Praxis forged M30, custom offset - Original and scuffed from shoe rub.
CASSETTE: SRAM PG-1130, 11-speed, 11-42t - Original but still have good life left in it.
CHAINRING: Burgtec 34 Tooth 104BCD Steel - Fitted when the bike was new but still has plenty of life left.
RIMS: Roval 29, hookless alloy, 30mm inner width, tubeless ready - Plenty of scratches back and front with one very small dent on the rear rim.
FRONT HUB: Specialized, sealed cartridge bearings, 15x110mm thru-axle, 28h - Original and in good condition.
REAR HUB: Specialized, sealed cartridge bearings, 12x148mm thru-axle, 32h - Original and in good condition.
SPOKES: DT Swiss Industry - Original and in good condition.
FRONT TIRE: Hillbilly Black Diamond 29x2.6" and also Butcher, GRID TRAIL casing, GRIPTON® compound, 2Bliss Ready, 29x2.6"
REAR TIRE: Hillbilly Black Diamond 29x2.6" and also Eliminator, BLCK DMND Casing, 2Bliss Ready, 29x2.3"
TUBELESS: Bike set up tubeless with original Specialized valves and Orange Seal Standard sealant
SADDLE: Burgtec Cloud Chromoly - Rails are a a bit rubbed from my shorts but otherwise in good condition
SEATPOST: X-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SRL LE lever, 34.9mm, 170mm - Original and in good condition.
SEAT BINDER: Specialized bolt-type, alloy, 38.6mm - Original and in good condition.
MOTOR: Specialized 2.1, custom Rx Trail-tuned motor, 250W nominal - Motor replaced under warranty and is now the latest updated version with the new software too.
REMOTE: Specialized TCU, 10-LED State of charge, 3-LED Ride Mode display, ANT+/Bluetooth® - Original and in good condition.
BATTERY: Specialized M2-700, integrated battery w/rock guard, 700Wh - Original and in good condition.
CHARGER:Custom charger, 42V4A w/ Rosenberger plug - Original and in good condition. Comes with storage box and instruction manuals.
WIRING HARNESS: Version 3 Custom Specialized harness - Updated from the original version to the latest V3 version
