Sold 2020 Specialized Kenevo Expert S3: £5800
Jorow47
Glasgow
Bike / Product Year: 2020
Manufacturer: Specialized
Model: Kenevo Expert
Size S3
Asking Price: £5800
Location Strathaven
Description Specialized Kenevo Expert 2020. Size S3 (Medium), Great condition. Bought from & looked after by Berkshire Cycles. Invisiframed from new. Magura MT7 pro brakes with 220mm front and 203mm rear rotors. Only 370 miles, 100% motor and battery condition. 700 watt hour battery. 180mm of front and rear travel. Balance of transferable warranty with over 2.3 years on the motor, battery etc… Bash plate, mudguards, Hope peddles, charger & manuals all included. Price £5800. Collection only.
Full Spec:
FRAME: Specialized M5 Premium Aluminum, 27.5 Trail Geometry, integrated down tube battery, enclosed internal cable, Command Post routing, 148mm spacing, fully sealed cartridge bearings, 180mm of travel
FORK: RockShox Boxxer Select RC, 27.5, DebonAir, 20x110mm Boost™, 35mm chassis, 180mm of travel
REAR SHOCK: RockShox Super Deluxe Coil Select, 62.5x230mm, S3: 500lb
FRONT HUB: Specialized, sealed cartridge bearings, 15x110mm spacing, 32h
REAR HUB: DT Swiss 370, 6-bolt, 12x148mm thru-axle, 32h
SPOKES: DT Swiss Industry
RIMS: Roval 27.5" Alloy DH, 28mm internal width, 32h
FRONT TYRE: Michelin e-wild 27.5 x 2.6"
REAR TYRE: Michelin e-wild 27.5 x 2.6”
CHAINRINGS: 34T, Hope
SHIFT LEVERS: SRAM S700, single-click lever
REAR DERAILLEUR: SRAM GX, long cage, 11-speed
CASSETTE: SRAM PG-1130, 11-speed, 11-42t
CHAIN: KMC X11ET, 11-speed w/ Missing Link™
FRONT BRAKE: MAGURA MT7 Pro 4-piston caliper, hydraulic disc, 220mm
REAR BRAKE: MAGURA MT7 Pro 4-piston caliper, hydraulic disc, 203mm
HANDLEBARS: specialized, 7050 alloy, 6-degree upsweep, 8-degree backsweep, 27mm rise, 800mm width
GRIPS: Specialized Sip grip, half-waffle
STEM: Specialized Direct Mount DH Stem, two-piece, forged alloy, 45mm
SADDLE: Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SEATPOST: Command Post IRcc, 16-position micro-height adjustable, two-bolt head, bottom mount cable routing, remote SRL lever, 34.9mm, 160mm of travel
SWAT : Specialized Z-Cage w/EMT Cage Mount MTB Tool
MOTOR: Specialized 2.1, custom Rx Trail-tuned motor, 250W nominal
UI/REMOTE: Specialized TCU, 10-LED State of charge, 3-LED Ride Mode display, ANT+/Bluetooth®
BATTERY: Specialized M2-700, integrated battery w/rock guard, 700Wh
CHARGER: Custom charger, 42V4A w/ Rosenberger plug
PEDALS: Hope F20
    672K
