Ickle_legs
2020 Spec.Levo alloy, size medium, owned by this lightweight OAP from new (purchased from Freeborn Bikes)
Full 29er, was Base model but upgrades (see below) think put it on par with the Comp of the same year.
Upgrades
Original manuals, proof of purchase and papers for warranty work will be provided
Collect only, no swaps/p.ex
Upgrades
- SRAM Guide RE 4-pot brakes
- Shimano XT 11spd shifter and rear derailleur
- Rockshox Yari fork
- air shaft now 160mm(was 150mm) and upgraded to latest C1 version
- damper upgraded to Charger2.1 RC2
- Mileage
c.1100 miles on original motor
+ c.220 miles since motor replaced under warranty - Electricals
- Motor replaced last year under warranty as was ‘battery to motor’ power cable
- battery had just 46 charge cycles
- Tyres
- Maxxis Minions DHF/DHR still with fair amount of tread
- tubeless
- Brake pads
- Gorilla pads fitted and pretty certain don’t need changing for a while
- Grips & saddle
- Both OE and prob.as new as I’d used aftermarket grips & saddle
- Paintwork
- Some chips and light scrapes, all cosmetic
Worst bit is on driveside when chain broke and whacked the chainstay
- Freehub (i.e. NOT the wheel hub)
- both bearings were replaced this May
NB.front & rear wheel hub bearings were also checked this May and were OK at the time (only done couple of rides since)
- Warranty
- motor (the key one I think): I understand the remaining motor warranty can be carried over to subsequent owner if they have the original proof of purchase (which you will have). Hence should be several months motor warranty left (runs out end Jan.2024)
