Levo Gen 2 2020 Levo - Rear brake line - which one?
kombos
250
309
Arizona
Need to replace my rear brake line and not sure which kit to get. I found this one, but it has a fixed banjo versus the threaded banjo on my 2020 Comp. Will this banjo fit my Guide RE caliper (just not have the threaded fitting) or should I use another kit?
Appreciate any input….
4B79F8FD-6B4A-4672-B5E1-E8B445EDBBB4.jpeg 3E7C5849-6CB6-4948-84CD-F01B25D2FAEA.jpeg
salko
1,241
837
SLO
This is not exactly the right one for Code RE, but you you can use it anyway if you cut fixed banyo off. For Guide RE you need the same olive connection as on the lever side. So basically you need only bare hose and two olives connections which can be much cheaper than buying this kit with fixed banjo...
kombos
250
309
Arizona
Thanks salko….
Update: Got it fixed. It was actually quicker and cheaper to get this kit, and just chop off the banjo….
