For Sale (BIKE) 2019 Yakima Highspeed: 120
Steve33
Kendal, UK
Bike / Product Year: 2019
Manufacturer: Yakima
Model: Highspeed
Asking Price: 120
Location Kendal, cumbria
Description Used but in good condition, collection only
Yakima highspeed, roof bar mounted, front fork holding, cycle carrier.
Yakima’s HighSpeed rack fits virtually all cross bars and is a very secure way of carrying your bike.
No part of the rack touches the bike frame or cables so you don't need to worry about scratching your frame.
It's quick and easy to install - no tools are required. After you've removed the front wheel, re-insert the front axle (for thru-axle's) or use the supplied 9mm skewer (for quick-release forks). Place the bike onto the rack then tighten the TorqueRight knob until you hear a reassuring click. Secure the rear wheel using one of the two different length ratchet straps supplied.
Other features:
The adjustable rear wheel holder takes a range of tyre sizes, from racing bike tyres to fat bikes up to 5"
Takes both quick release (9mm) and thru axle bikes (12mm, 15mm, 20mm), including boost spacing and thru-axle fat bikes
Integrated cable lock secures your bike to the rack while another lock secures the rack to your roof bars
An additional lock secures thru-axle bikes at the fork
Fits around bars up to 88mm wide by 44mm deep
Adapters are also available that allow you to fit the rack to T-track aluminium bars using the T-track channel
Max Bike weight 18kg
    672K
