Sold 2019 Sram Kenevo Code R brake set £175: £175
Funky Bolly
Newport wales
Bike / Product Year: 2019
Manufacturer: Sram
Model: Kenevo Code R brake set £175
Asking Price: £175
Description: Hi , here's a set of SRAM code R brakes , 200mm rotors taken off my Kenevo I bought NEW last Saturday ( so the only use they've had is a 2 laps around Berkshire turbo store test ride ! ) they come with a SRAM bleed kit and piston bleed holder and a bottle of new 5.1 fluid .I had to remove pipe from rear brake to thread thru frame ,but there's a new olive n barb for refitment . Also if you're buying for a Levo brake upgrade the piggy back mounts for gear trigger and dropper switch they're still on brake brackets so it'll be a straightforward swap .The reason these are for sale is that I had set of Saints n ice tech rotors that I had to put on my analog enduro but got the Ebike bug then here I am .
