For Sale (BIKE) 2019 Specialized Kenevo Comp: £3200
Kenevocomp
Hampshire, U.K
Bike / Product Year: 2019
Manufacturer: Specialized
Model: Kenevo Comp
Asking Price: £3200
Description: Specialized Turbo Kenevo Comp 2019 small frame in Battleship/Mojave
I have looked after this bike and it is in excellent condition due to the fact it has been invisiframed from almost new
It has covered less than 200miles (only just 199.7)battery is on 100% health
I have upgraded the tyres to black diamond casing specialized (suited for e bike) very recently, barely used as you can see from the pictures
Also running tubeless system a must for trail riding
This bike rides absolutely perfect and wants for nothing
Bike does NOT come with pedals or the swat tool in the head tube as these are being transferred to my new bike
This bike rides absolutely awesome up and down hills and on the road absolutely anywhere especially due to the 27.5 (650b) wheels - selling due to to upgrading to the latest model
This bike still has just under a year of its battery/motor warranty left (with original purchase receipt) and comes with all manuals and charger etc
Collection only from GU307
£3200 for a very capable trail ready bike please no silly offers they won’t be accepted I would rather hang onto it
Specification from the specialized website below
SPECIFICATION
FRAME Specialized M5 Premium Aluminum, 27.5 Trail Geometry, integrated down tube battery, enclosed internal cable routing, 148mm spacing, fully sealed cartridge bearings, 180mm of travel
FORK RockShox Yari RC 27.5", Boostâ„¢, 15x110mm, 180mm of travel
REAR SHOCK FOX Van RC Coil, S: 400 lb/in, M: 450 lb/in, L: 500 lb/in, XL: 550 lb/in, 216x57
FRONT HUB Specialized, sealed cartridge bearings, 15x110mm thru-axle, 28h
REAR HUB Specialized, sealed cartridge bearings, 12x148mm thru-axle, 28h
SPOKES DT Swiss Industry
RIMS 27.5" alloy, 20mm depth, 30mm internal width
INNER TUBES Presta, 40mm valve
FRONT TYRE Butcher, GRID casing, GRIPTON® compound, 2Bliss Ready, 27.5 x 2.6"
REAR TYRE Butcher, GRID casing, GRIPTON® compound, 2Bliss Ready, 27.5 x 2.6"
CRANKSET Praxis, 2D cold-forged alloy, custom offset, 165mm
CHAINRINGS 32T, custom steel
SHIFT LEVERS Shimano SLX, 11-speed
REAR DERAILLEUR Shimano XT, Shadow Plus, GS cage, 11-speed
CASSETTE Shimano SLX, 11-speed, 11-46t
CHAIN KMC X11ET, 11-speed w/ Missing Linkâ„¢
FRONT BRAKE SRAM Guide RE, 4-piston caliper, hydraulic disc, 200mm
REAR BRAKE SRAM Guide RE, 4-piston caliper, hydraulic disc, 200mm
HANDLEBARS Specialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 27mm rise, 800mm width
GRIPS Specialized Sip Grip, half-waffle, S/M: regular thickness, L/XL: XL thickness
STEM Specialized Trail, 3D-forged alloy, 4-bolt, 6-degree rise, 45mm
SADDLE Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SEATPOST X-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SRL LE lever, 34.9mm, S: 125mm, M/L/XL: 150mm of travel
SEAT BINDER Alloy, 38.6mm
MOTOR Specialized 1.2E, custom Rx Trail-tuned motor, 250W nominal
BATTERY Specialized M1-460, integrated Trail Display, ANT+/Bluetooth® module, 460Wh
CHARGER Custom Specialized 42V2A Charger w/ Rosenberger plug, AC power cord included
WIRING HARNESS Custom Specialized wiring harness
PEDALS Specialized Dirt
As with any product, specification is subject to change without prior notification. You are advised to confirm current specification before buying.
