2019 Levo Expert with 170mm?
Tuckya'in
14
14
Washington State
Just got done with first ride on the new Levo. Range is a mind blower compared with 17 Levo and19 Kenevo. I found the fork and probably shock a bit too harsh for me. My favorite riding zone has a lot of rough DH type stuff. I have a new Fox 36 ESpec in the shop but it is 170mm. Would raise the front end 1/2 inch which I could make up with sag I suppose. Has anyone messed with the front end yet? Would a 170 front/150 rear be stupid? Opinions welcome.
BigFoot
91
46
Bethesda, Maryland USA
I’m running a fox 36 160mm 44 offset and a 210 x 55 rear fox float shox with all of the volume spacers removed out of both of them , I would like to try a 170 mm 36 with at least 30% sag as my 160 is not getting full travel at 30%
My bottom bracket is definitely not too high with the 160 I put 175mm cranks on trying to get longer range out of the bike these Cranks do get Pedal strikes
Let me know how the 170 goes
SinCityJets
22
15
Redding, Ca
@BigFoot, why did you change from the 51 offset to the 44 offset when switching to the 160?
Thanks!
Chad
