Sold 2018 Specialized Turbo Levo Carbon Comp: £2,999
SJM25
Buckhurst hill
Bike / Product Year: 2018
Manufacturer: Specialized
Model: Turbo Levo Carbon Comp
Asking Price: £2,999
Description:
Specialized Turbo Levo 2018 Carbon Comp size large
I purchased the bike new from Specialized concept store Ruislip in September 2017 and is in mint condition, bike has been updated to the latest firmware by specialized. Only reason im selling is to upgrade to the new turbo Levo expert..... Scroll down for pictures of the
bike.
Battery health 100% charge cycles 19
Bike as done only 610 miles as it only gets used between spring and autumn, used for single track, no jumping so not had a hard life at all
Tyre's fitted in July 2019 and have done around 100 miles, they are in great condition and running tubeless.
Front tyre schwalbe Magic Mary 2.6
Rear tyre Schwalbe Hans Dampf 2.6
Bike had invisiframe put on from new
Bike spec....
FRAME - FACT 9m carbon chassis / M5 Alloy rear triangle, 6Fattie/29 Trail Geometry, Integrated down tube battery, enclosed internal cable, Command Post IR routing, 148mm spacing, fully sealed cartridge bearings, 135mm of travel
DRIVETRAIN CHAIN - KMC X11ET, 11-speed w/ Missing Link
CRANKSET - Custom alloy crankarms
SHIFT LEVERS - SRAM GX, one-click shift-lever
CASSETTE - SRAM PG-1130, 11-speed, 11-42t
CHAINRINGS - Forged steel, 32T
REAR DERAILLEUR - SRAM GX, long cage, 11-speed
UI/REMOTE Trail Handlebar Remote, motor mode switch & walk-assist
BATTERY - Specialized M1-504, integrated Trail Display, ANT+/Bluetooth® module, 504Wh, Mission Control App connectivity
CHARGER - Custom charger, 42V4A with Rosenberger plug
MOTOR - Specialized 1.3, custom Rx Trail-tuned motor, 250W Nominal
WIRING HARNESS -Custom Specialized wiring harness
FRONT HUB -Specialized, sealed cartridge bearings, 15x110mm spacing, 24h
REAR HUB - Specialized alloy disc, sealed cartridge bearings, 12x148mm, 10-/11-speed freehub, 28h
SPOKES -DT Swiss, stainless
RIMS - Roval Traverse 27.5, hookless alloy, 38mm inner width, tubeless ready, 24/28h
SADDLE -Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SEATPOST - Command Post IRcc, 12-position micro-height adjustable, alien head design, bottom mount cable routing, remote SRL lever, 30.9mm, M : 125mm of travel
STEM - Specialized Trail, 3D forged alloy, 4-bolt, 6-degree rise
HANDLEBARS - Specialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 27mm rise, 720mm width
GRIPS- Specialized Sip Grip, half-waffle, M/XL: XL thickness
REAR SHOCK - RockShox Monarch RT, Rx Trail Tune, AUTOSAG, rebound and 2-position compression adjust, 197x48mm
FRONT BRAKE - SRAM Guide RE, hydraulic disc, 200mm
REAR BRAKE -SRAM Guide RE, hydraulic disc, 200mm
SEAT BINDER -Specialized, alloy, 34.9mm
FORK - RockShox Revelation RC 6Fattie/29, 51mm offset, 34mm stanchions, 150mm of trave
Please feel free to contact me or ask any questions, happy to answer anything.
regards
Sean
