Sold 2018 Specialized Kenevo Expert: 2500
Stompweaver
Stafford
Bike / Product Year: 2018
Manufacturer: Specialized
Model: Kenevo Expert
Asking Price: 2500
Description: 2018 Specialized Kenevo Expert XL
Cali Fade – used but in good condition. I had it Invisframed from new including fork legs and crank arms, most of the marks are on the Invisiframe. This could be removed but I have left it on for the new owner. There some other cosmetic marks on the bike as it isn’t brand new but these are only minor and what you would expect from a used bike. There are no dents or cracks.
Rock Shox Lyrik fork recently serviced and seals replaced with SKF upgraded seals fitted with Maxle Stealth bolt through front axle.
Ohlins TTX22M rear shock
Upgrades from standard spec include Hope Hoop wheels – Pro 4 Evo hubs with 35W 35mm wide Hope rims. Original wheels can be swapped for these and the price adjusted if required.
Schwalbe Magic Mary Apex 27.5 x 2.8 Soft compound front tyre and Schwalbe Eddy Current 27.5 x 2.8 soft compund rear tyre running Stans NoTubes sealant and Stan’s valves. I also have the original Specialized Butcher Grids.
Renthal Fatbar 35mm bars and 35mm Renthal Apex stem. Again I have the original Specialized bar and stem so these can be removed and the price adjusted. Standard Specialized grips.
Rock Shox Reverb 150mm Stealth seatpost with 1X lever with Body Geometry Henge saddle and Specialized seat clamp.
Shimano XT rear mech and shifter with Problem Solver mount to attach to SRAM Code brake lever. Nearly new chainring, XT chain and SLX cassette.
Motor replaced by Berkshire Cycles in March this year along with the main power cable and it has not had much use since as I broke my foot shortly after it was replaced!
Battery has no faults, charges perfectly and LED’s all light up green as they should.
Recent genuine SRAM brake pads.
Specialized side exit SWAT bottle cage with EMT tool and Specialized top cap chain tool and spare chain link in the fork steerer tube.
I have all the original manuals and booklets.
It will not come with any pedals. I have left mine on so it can be test ridden but they will be removed before sale.
It’s a great bike and I’ll be sorry to see it go but I have bought a new toy. :)
