For Sale (BIKE) 2018 Specialized Kenevo Comp Large: £3250
Vaughany21
Wales
Bike / Product Year: 2018
Manufacturer: Specialized
Model: Kenevo Comp
Size Large
Asking Price: £3250
Location South Wales, UK
Description 2018 Specialized Kenevo comp.
Size - Large
Suspension
Fork - Rockshox Yari Charger RC debonair 180mm travel
Shock - Fox Van RC with Fox SLS spring 700lb x 2.4/61mm
Brakes
Sram Guide RE front and rear
1 ride old Sram Sinistered pads
220 mm Magura rotors front & rear (awesome stopping power)
Magura mounts
Cockpit
Deity 35mm bars, 790mm wide, 40mm rise
Renthal Apex 50mm stem, 35mm diameter
DMR deathgrip grips
Bergtec stem cap, Bergtec stem spacers
Chainset
Praxis crankset 165mm
Bergtec flat pedals
Hope 32t chainring with hope chainring bolts
Shimano SLX 11-46t casette
Shimano SLX 11 speed shifter
Shimano XT 11 speed derailler
KMC 11 speed chain
Hope orange jockey wheels
Wheelset
Hope Pro4 hubs with Hope 35w rims
Specialized Butcher T9 Gridgravity tires 27.5 x 2.6 1 ride old
Muc-off tubeless valves set up tubeless
Bergtec axles
X fusion Manic seatpost 125mm
Ergon SM enduro comp seat - Oil slick rails
RRP proguard front & rear mudguards
Standard spec - https://www.specializedconceptstore.co.uk/product/13823/2019-turbo-kenevo-comp/
I bought this Kenevo as the 2nd owner in April 2022. The motor had only done 250 miles but had suffered failure of the sprag clutch from water ingress resulting in the motor not freewheeling. I sent the motor off to Performance line bearings where the crankshaft was replaced along with having the brose motor upgrade. The motor runs superbly now and works amazing. I have only completed 35 miles since the overhaul.
https://www.ebikemotorcentre.com/brose-motor-upgrade-service/
All frame bearings are good with no play.
Motor currently has 286 miles
Battery is the 500wh with 100% health and 45 charge cycles
All modes work and the handlebar selector works along with walk assist
A well specced bike with all the essential work carried out. As with all used items there are some marks. The underside of the motor casing has some marks but structurally sound. The rear of the frame seat post has some marks from a cycle carrier.
A spare set of tyres will be included and a spare spring.
The original receipt from Don Skene will be supplied along with the receipt from performance line bearings.
Any questions please ask.
