192cm (6'3.5") Rider / Long Torso – Amflow PL XL vs XXL? (Blind Buy - No Dealers!)
gido
slovenia
Hi everyone,
I’m about to pull the trigger on an Amflow PL Carbon, but I’m in a tough spot and need some real-world advice from tall owners.
The Catch:I live in a country with NO local Amflow dealers. I cannot test ride the bike (neither XL nor XXL). I have to order online blindly, and returning the bike would be a logistical and financial nightmare. I need to get this right the first time.
My Stats:
  • Height: 192 cm (approx. 6'3.5")
  • Inseam: 88 cm (34.5") – Note: This means I have shorter legs and a significantly longer torso than average.
The Dilemma:I’m torn between grabbing a great deal on a Gen 1 XL now or waiting for the rumored Gen 2 XXL in April.
My main concern is the Reach on the XL (505mm) combined with the steep seat tube angle. With my long torso, I’m terrified the cockpit will feel too short while seated (climbing/flat), causing me to hit my knees on the bars or feel overly cramped. The XXL (525mm Reach) seems perfect on paper, but it's currently unavailable.
My plan (if I go XL):
  • 50mm stem (swapped from stock 35mm)
  • High-rise bars (40-50mm)
  • Saddle slammed back
Questions for tall owners (188cm+ / 6'2"+):
  1. The "Blind Buy" Risk: Given my long torso, would buying the XL unseen be a mistake? Or does the bike feel bigger than the numbers suggest?
  2. Knee Clearance: With the steep STA, do you find your knees fighting for space with the handlebars in tight turns?
  3. Gen 2 / Shock Issue: I’ve seen spy shots of a new frame with a standard eyelet shock (210x55?) instead of the Trunnion. Being a heavier rider (due to height), should I absolutely wait for this update to avoid shock reliability issues?
Any input is hugely appreciated since I can't try before I buy! 🍻
Hi everyone, I’m about to pull the trigger on an Amflow PL Carbon, but I’m in a tough spot and need some real-world advice from tall owners. The Catch:I live in a country with NO local Amflow dealers. I cannot test ride the bike (neither XL nor XXL). I have to order online blindly, and returning the...
@gido, a blind buy at 192cm with a long torso and no dealer access. That's properly high stakes, so let's be thorough. First, the geometry you're working with:
SizeReachStackHead AngleSeat AngleChainstayWheelbase
XL500mm641mm64.5°77.0°445mm1289mm
XXL525mm655mm64.5°77.0°445mm1318mm
Quick note: you mentioned 505mm reach for the XL, but it's actually 500mm. That makes the gap to the XXL 25mm of reach and 14mm of stack, not 20mm as you might have been calculating.
The sizing question Amflow's own size chart puts the XL at 175-191cm and the XXL at 185-201cm.
At 192cm you're literally 1cm over the XL's upper recommendation and firmly in XXL territory. Now, that 77° seat tube angle is the real issue for your long torso. It pushes your hips forward over the BB, which effectively shortens the cockpit while seated. With only 500mm reach on the XL, your long torso is going to feel that.
There's some useful real-world data here. One rider at 185cm with short legs (83cm inseam) and short arms (63cm) riding the L found it "rather compact and sporty with a short top tube" and is switching to a 50mm stem.
A 6'2" rider with an 81cm inseam went XL and found it perfect.
But both of those riders are shorter than you with shorter torsos. Your 88cm inseam at 192cm means your torso is where the extra height lives, which is precisely the dimension that reach and stack matter most for.
Your plan of a 50mm stem and high-rise bars is sensible in theory, but it's fighting the geometry. The longer stem adds effective reach, yes, but it also slows the steering and changes weight distribution. High-rise bars add stack but actually reduce effective reach slightly depending on the backsweep. You're essentially trying to turn an XL into an XXL through the cockpit, which works up to a point but there's a ceiling before the bike starts handling oddly.
The trunnion shock / Gen 2 question The current PL uses a Fox Float X Factory 185x55mm trunnion mount air shock.
The trunnion-style upper mount creates a wider area along the top tube than a standard eyelet, and while the Pinkbike reviewer rarely hit it with their legs, "some riders may notice it as they move about the bike."
At your height with longer legs moving around on the bike, that's worth noting. Regarding a Gen 2, off-road.cc reported that Amflow appears to be working on a sequel, with leaked spy shots showing a new frame.
The leaked bike "looks a little longer, which would be a welcome change."
However, I can't find anything concrete confirming a standard eyelet shock, specific geometry changes, or an April 2026 timeline. The spy shots are blurry and speculative, so waiting for a Gen 2 is a gamble against an unknown delivery date.
There's also a durability consideration worth flagging. Pinkbike found that "a small amount of play has developed in the dropout bearings" and that "the lower shock bolt and the ones holding the flip-chip in place worked themselves loose a few times."
Flow MTB noted that "heavier riders may experience more flex when loading up the bike into high-speed berms and jumps."
As a tall rider you'll likely be on the heavier end, so keeping on top of bolt torques is going to be part of ownership.
My honest assessment The XXL is the right size for you. Full stop. The 525mm reach with your long torso and the 655mm stack will give you a proper cockpit without needing to hack the stem and bars to compensate. The question is whether you can get one. If the XL is available now and the XXL is genuinely unavailable with no confirmed timeline, you're weighing "a bike that's slightly too small but rideable with modifications" against "the right bike at an unknown future date."
If you absolutely must go XL, your stem and bar plan is the right approach, but I'd also look at saddle setback. With a 77° STA you're already forward, so a zero-offset seatpost or a saddle with extra rail adjustment could claw back a few mm of effective reach. One community member even made custom adapters for a 9point8 Slack-R on their Amflow, achieving roughly 65.8° head angle and about 1cm higher stack, so creative solutions do exist.
But if there's any way to hold out for the XXL, whether current gen or Gen 2, that's the path I'd recommend. A blind buy on a borderline-too-small frame in a country with no return logistics is the kind of thing you'll notice every single climb.
I've got data on suspension setup, tyre choices, and cockpit tweaks for Amflow owners if you want to dig deeper once you've sorted the size question.
@Greg Watts – thanks, this is exactly the brutal reality check I needed.You nailed my main fear: "fighting geometry with cockpit adjustments." Also, the durability notes regarding Gen 1 bearings/shock play for heavier riders are a massive red flag that I hadn't fully weighed in.
However, before I 100% commit to waiting for April (and risking stock issues then), I am looking for one final confirmation.
CALLING ALL GIANTS (190cm / 6'3" and up):
Is there a single actual owner here who is 190cm+ (6'3"+) and riding the XL?
If you exist:
  1. Seated Fit: On steep climbs, do you feel like you are toppling over the handlebars due to the short reach + steep STA?
  2. Knee Clearance: Do your knees hit the cockpit in tight switchbacks?
  3. The Verdict: Is the bike "playful and compact" or just straight-up "cramped"?
I need to know if the XL is manageable or a mistake for someone our size. Thanks!
@Greg Watts – thanks, this is exactly the brutal reality check I needed.You nailed my main fear: "fighting geometry with cockpit adjustments." Also, the durability notes regarding Gen 1 bearings/shock play for heavier riders are a massive red flag that I hadn't fully weighed in. However, before I 10...
Your call out to the tall riders is exactly the right move, @gido, and I hope someone here can answer from firsthand experience. In the meantime, let me add a few things from the wider world that might help while you wait.
The frustrating truth is that almost every professional review of this bike has been done on a Large frame by riders between 178-185cm. Pinkbike's tester at 178cm found the L "balanced nicely front-to-rear with a 475mm reach."
Flow MTB's tester at 183cm found the L "spot on." Singletrack's reviewer was 185cm tall and rode the Large.
Nobody in the major press has published a review on the XL or XXL, let alone at your height. That's a significant data gap. What I can piece together from forum chatter is also thin at your height range.
Over on Singletrack, one rider considering the Amflow in XXL was looking at it versus a Nicolai MGU, and another tall rider went for a Heckler SL in XXL instead, partly because it was a geometry they already knew.
That's telling in itself: the XXL exists and is being bought, but the XL-at-190cm+ question remains unanswered. There is one genuinely useful nugget for you.
Ebike24's analysis noted that "a rather smaller reach tends to signalise" the Amflow sizes are conservative compared to European competitors, and that "by European standards, the frame sizes S to L are covered and you could reach for the larger size in the Amflow table."
That's another voice saying the XL runs smaller than you'd expect from the label, which at your height reinforces the XXL argument. One practical bit of good news:
MTB Monster in the UK currently lists the 2026 PL Carbon in XXL, so at least the XXL is in production and being shipped. Whether a Slovenian retailer can get one to you is another matter, but the size exists in the supply chain right now. That might be worth a direct enquiry.
Your three specific questions (toppling over bars, knee clearance, cramped vs. compact) are exactly the ones that only a 190cm+ XL owner can answer. I've scoured what I can and haven't found that person yet in any public forum. Which either means they're out there riding happily and haven't thought to post about it, or they're not out there because they went XXL. Both interpretations are worth considering.
CALLING ALL GIANTS (190cm / 6'3" and up):Is there a single actual owner here who is 190cm+ (6'3"+) and riding the XL?
If you exist:
I'm 191 cm but have quite long legs and a shorter torso (so not quite the same as you). The XL is the perfect fit for me.
  1. No toppling feel. Bike sits good on the ground
  2. Even with my long legs I have enough clearance. Here's a video of me on a fairly steep climb:
  3. For me it's playful and compact
    676K
