Hi everyone,
I’m about to pull the trigger on an Amflow PL Carbon, but I’m in a tough spot and need some real-world advice from tall owners.
The Catch:I live in a country with NO local Amflow dealers. I cannot test ride the bike (neither XL nor XXL). I have to order online blindly, and returning the bike would be a logistical and financial nightmare. I need to get this right the first time.
My Stats:
My main concern is the Reach on the XL (505mm) combined with the steep seat tube angle. With my long torso, I’m terrified the cockpit will feel too short while seated (climbing/flat), causing me to hit my knees on the bars or feel overly cramped. The XXL (525mm Reach) seems perfect on paper, but it's currently unavailable.
My plan (if I go XL):
My Stats:
- Height: 192 cm (approx. 6'3.5")
- Inseam: 88 cm (34.5") – Note: This means I have shorter legs and a significantly longer torso than average.
- 50mm stem (swapped from stock 35mm)
- High-rise bars (40-50mm)
- Saddle slammed back
- The "Blind Buy" Risk: Given my long torso, would buying the XL unseen be a mistake? Or does the bike feel bigger than the numbers suggest?
- Knee Clearance: With the steep STA, do you find your knees fighting for space with the handlebars in tight turns?
- Gen 2 / Shock Issue: I’ve seen spy shots of a new frame with a standard eyelet shock (210x55?) instead of the Trunnion. Being a heavier rider (due to height), should I absolutely wait for this update to avoid shock reliability issues?
