Sold £900: 2020 Ohlins RXF36 m.2 Trail Coil TTX18 Forks. 160mm. 29 or 27.5, 44 offset, 110x15 hub, 3 springs
Tobers
140
309
England
More pics lower down.
Bike / Product Year:
2020
Manufacturer: Ohlins
Model: RXF36 m.2 Trail Coil TTX18 Forks. 29 or 27.5, 44 offset, 110x15 hub, 3 springs
Size 27.5 or 29, 160mm travel, 44mm offset, 110x15 Boost
Asking Price: £900 + postage
Location Guildford, UK
Description For sale here are my very sweet Ohlins RXF36 m.2 Trail coil forks, with 55lb (fitted) and spare 60lb and 65lb springs.
They are set to 160mm travel and 44mm offset, and have been on my Specialized Levo SL where they are just amazing. I'm only selling as I've been persuaded to buy some EXT ERAs. Needless to say they are a huge improvement over the stock forks, being silky smooth with no stiction, and that lovely plush coil feeling. Even if you are on a high spec air fork, these will feel great.
New price for these is £1320 from TF Tuned, plus springs at £50 each, so this whole package would be £1470 new.
The steering tube is cut to 210mm which gives plenty of room on my XL Levo SL, so should be fine for pretty much any bike.
Also included is a brake calliper extender to suit the spacing on the SL with SRAM Guide Ultimate callipers.
I removed the garish yellow "O" stickers on the lowers and used some more subtle blue and yellow ones on the bottom of the lowers. You can buy the big yellow ones from eBay if you really want to add them back. I've included some additional Ohlins stickers if you fancy them.
Purchased from TFTuned in October 2020, so these are less than a year old and haven't had enough running for a lowers service yet. There are some small scuffs on the lowers that you can see in the pics and some other general wear, and the top cap for the spring compartment has some scuffs from the socket I used to open it up.
Firm price is £900 plus postage. Inspect and collect in Guildford if you like.
Blurb from TFTuned:
Code:
PRODUCT DESCRIPTION
Ohlins RXF 36 m.2 Air TTX18 Fork 150-180mm (Please include your preferred travel before checking out)
38mm or 46mm offset for 27.5" model , 44mm or 51mm offset for 29" model
Features
TTX-technology
Coil: travel 130 -170 mm
Independent spring system
Independent damper system
36 mm upper tube diameter
Offset 46 mm or 38 mm
E-bike approved
Race proven setting bank
Overall improvements for reducing friction
Possible to change between coil and air spring
Compatible maximum tire sizes 27.5 x 2.8
Compatible maximum tire sizes 29x2.8 / 27.5+ x 3.2
The race proven TTX 18 dampening from the DH38 Race Fork has been reworked to give optimal traction and control on trails and Enduro race courses. The TTX 18 cartridge kit featuring trail-optimized 18 mm piston for improved small bump sensitivity. With increased damping pressure bandwidth the damping valve response and sensitivity has improved.
The adjustment range specifically for trail to Enduro race use with 15 clicks of low speed compression and low speed rebound. For high speed compression you get 3 clicks plus a climb mode setting.
Improved tire clearance, the chassis will take up to a whopping 27.5×2.8. There are many technical improvements in the fork but we did not stop there, the design has also been updated and matches what you see on the race courses.
