33red
Ya, a quick search gave me a Giant 2020
Giant SyncDrive Pro, powered by YAMAHA
They’re just prototype frames of the 2019.Is you watch the embn video with the specialized guys in it they are riding unmarked Levos that are probably the 2020 versions. They looked identical if they were the 2020 version.
There is much more interesting things in this video than their bikes. There is so much between the lines to hear...;-)They’re just prototype frames of the 2019.
YepThere is much more interesting things in this video than their bikes. There is so much between the lines to hear...;-)
Thats what we already all know...2020 Turbo Levo FSR use same frame as MY19, but have some changes in spec. #Lyrik select #Delux select (and+), #Rockshox 35 #TranzX
Spoil sport.They’re just prototype frames of the 2019.
While I wouldn’t ask you to break any confidentiality if you were in the market for a new kenevo would you wait for the new one to come out?
You will not regret your decision.Today I tested a Giant Trance 1. It was really good looking. The Yamaha motor felt fine as far as pedal feel and was natural enough, but it was too noisy for stealth. Also the battery tube was significantly thicker than the Specialized, and also can't do a 700 Wh battery. The MSRP was about $5800 and had GX 12 and Fox forks and was much nicer than a Levo base and even Comp. But, it was heavier (not much by lifting feel) and even though some random YouTube channel rated it the "best downhill ebike," it felt less slack and more forward than the Levo.
Also tried Haibike - the new one with the integrated battery. The Bosche motor was quieter than the Giant, but louder than the Brose. Feel was fine also!
I was trying to get a used or demo 2019 Levo base model. I only found a new one, but decided against the yellow and the build. It overall felt too compromised compared to the other bikes as per parts. The 2019 Comp I rode, in gray, while still not awesome parts, looked acceptable - but for how much more money it was, I didn't want to spend the difference unless I got the 2020 with the 700Wh battery. But, it is harder to get a deal on a 2020 of course. So, I bit the bullet and ordered a 2020 Comp in gray. While it was a lot of money, I felt like I would cry once. My other MTB is a 2013 Giant.
Yeprode with them both last Sunday and had an interesting chat ??
I used one for a 5 hour drive on my kenevo but I did add a strap to take the weight of the bike just in case. No problems otherwise.
You should have mentioned selling your 2 houses and your dogIndeed Marco had touched several thinks and we could interpret between the lines.
In one way I've understood, that I will have as a customer from Specialized a bike for my individual ride and terrain. That means to me, I need to buy 2-3 eMTBs from them;
- a heavy duty machine for bike park/downhill such as the new upcoming Kenevo 2020
- a light version, long range Levo for cross-country and bunny-hop/trial/trail funstuff (2021...)probably with Mahle Engine / Range Extender batterie as Creo
- and keep the old silent Levoas no of the future ones will be so quite anymore as T/S-Drive
Let's see what happen in Croatia/September
@johnwski - where are you in California?
Hi Coggbike,
Noticed you're also in California
Northern Calif, San Francisco East Bay
Two reasons: More space for better self cleaning while riding between tire and motor housing (frame) and for energy saving (as we heard in the latest EMBN video tires do effect up to 20%)This may have been covered, but why does the 2020 Comp have a 2.3 tire in the back rather than 2.6?
The 2019 had Butcher, GRID casing, GRIPTON® compound, 2Bliss Ready, 29x2.6" front and back. The 2020 went to a 2.3" Eliminator in the back for some reason.
It is hard to make sense of the build sheets since the info is all spread out. I was concerned about the forks as NX vs GX is no big deal.
2019 Levo base has RockShox Sektor RL DebonAir Boost 29" with 32mm stanchions. About a $430 Fork.
2019 Comp has RockShox Revelation Charger RC, 29" Boost™. This is a $600 Fork with 35m stanchions.
2020 base ????
2020 Comp is Rockshox Lyrik Select Charger RC Fork 29" , a $700 Fork with 35mm stanchions.
I didn't expect the Comps to go right up to 35mm diameters.
Yes, thats the Expert Carbon 2020.
