2019 Levo chainrings
AdrianWindo
I need to change my chainring from 32t to 34t / 36t. I can't find a steel wide narrow chainring, has any one else or have you gone for an alloy replacement? How is the alloy wearing?
thanks in advance
I wore out my stock steel 32 tooth and have an alloy 30 tooth from Praxis on it at the moment. It's wearing fast for me - my LBS thinks I'll be lucky to get 2 months out of it, as does Praxis, and I have to agree.
Praxis has a 36 tooth steel that'll bolt right on
eRING STEEL MTN 1X 104BCD - Praxis Works
For where I ride the 30 tooth is better. I just ordered a Wolf Tooth 30 tooth steel ring. It's pricey but it should last longer
At the moment only one of the planned Praxis eRing’s is available. I shall have to wait until the 34 tooth comes available
I got a 36 Oneup but it didnt came with nuts, any idea how to solve it?
It will be interesting to hear about the rate of wear.
I got a 36t Alu chrainring from Renthal and after 600 km already showing a lot of wear. My best guess is that I will get max 1000 km out of it before it’s worn completely. I’m going back to steel ring for sure.
Karsten
Karsten
Many thanks for the information, looks like steel is required - just where from?
This is how my alu chainring looks like after 600 km. As seen in the picture the teeth are getting out of shape and deformed as well.
Karsten
I ordered the praxis 34 tooth via the LBS this week , in stock , no problem
Not available in STEEL until later this year according to the Praxis Works website, you can get an alloy one. May be the website is incorrect, i shall contact them.
    677K
