Brake Pads
The pads are DO1S Resin SD4QD (4-pot). Also fitting are Shimano Saint BR-M810.
Are these OK?
@Silato
No. They are single pot. I used to have them on my other bike. The two pots have a central post hole and are wider. Google the spec I gave you and take a look.
Going from the shape and the Shimnao name, the ones at the bottom "Shimano/TRP".
Why not just remove a set of pads from your bike and take a look? It takes 20 seconds, if that
"The Shimano hydraulic BR-M520 / BL-MT501 disc brake offers the most powerful hydraulic disc brake in its class. Perfect for beginners and price-conscious cyclists. Ready to use, filled and easily mountable. With B01 resin brake pads. Pre-bled Caliper, Brake lever, and Pre-Bled hose."
or go in to your local bike shop and ask... they will probably out them in for you,
Hi.
I can fit them was just hoping to order some in now to fit in a few weeks. I'll have to get one out and have a look to make sure.
    Join 43,228
