For Sale (BIKE) UK-HAMPSHIRE - 2017 Scott E-Scale 920 Electric Hardtail - 1 month old - Includes Bosch Performance CX 2
Knobby
Hampshire, UK
Bike Year: 2017
Manufacturer: Scott
Model: Scott E-Scale 920 Electric Hardtail Mountain Bike Black - Includes Bosch Performance CX 250w With 500wh Battery
Asking Price: GBP 2495
Description: 2017 Scott E-Scale 920 Hardtail MTB Large 2 weeks old
Large
Only 1 Month old, 200 miles
Can arrange more pictures if needed.
Located in Hampshire, UK.
Spec from website
Key Specifications
• Frame - E-Scale / 6061 Alloy
• Fork - Rock Shox Recon Silver TK Solo Air
• Drivetrain - Shimano RD-M7000-SGS 10-Speed
• Brakes - Shimano M506 Disc 180 SM-RT54 CL Rotor
• Motor - Bosch Performance CX 250w System
• Battery - 500wh Battery / new Intuvia Display
Full Specification
• Frame - E-Scale / 6061 Alloy custom butted tubing internal cable routing / 148/12 IDS SL drop out
• Fork - Rock Shox Recon Silver TK Solo Air 15x100mm / Tapered Steerer / Poploc Lockout Reb. Adj. / 100mm travel
• Shock - N/A
• Number of Gears - 10
• Shifters - Shimano Deore SL-M610 / Rapidfire Plus 2 way release
• Chainset - FSA CK-745 MTB
• Chainrings - 15T
• Cassette - Shimano CS-HG50-10 11-36 T
• Chain - KMC X10
• Front Derailleur - N/A
• Rear Derailleur - Shimano RD-M7000-SGS DM Shadow Plus 10-Speed
• Pedals - Included
• Rims - Syncros X-25 / 32H / Tubeless ready
• Front Hub - Formula CL 71
• Rear Hub - Shimano Deore FH-M618-B
• Front Tyre - Maxxis Forekaster / 2.35 / 60TPI Kevlar Bead Dual compound
• Rear Tyre - Maxxis Forekaster / 2.35 / 60TPI Kevlar Bead Dual compound
• Front Brake - Shimano M506 Disc 180 SM-RT54 CL Rotor
• Rear Brake - Shimano M506 Disc 180 SM-RT54 CL Rotor
• Brake Levers - Shimano
• Handlebars - Syncros FL2.0 mini Riser / Alloy 6061 12mm rise / 9° / 740mm
• Grips - Syncros Pro lock-on grips
• Headset - Syncros OE / Tapered 1.5" - 1 1/8" semi integ. OD 50/61mm / ID 44/55mm
• Stem - Syncros FL2.0 6061 Alloy oversize 31.8mm / 1 1/8"-6°
• Saddle - Syncros M3.0
• Seatpost - Syncros / 31.6mm
• Post Clamp - Included
• Weight - 20.50 k
Hey man, good looking bike! Just a tip, since this a international forum please add a country of sale and wich currency the asking price is in. Euro or pound makes a difference :) good luck with your sale!
Bike Year: 2017
Manufacturer: Scott
Large
Spec from website
Key Specifications
Full Specification
• Shock - N/A
• Chainrings - 15T
• Chain - KMC X10
• Pedals - Included
• Weight - 20.50 k
How much are you asking? my Samedi has a seat suspension connection just below seat takes some of the jar away
Thanks sounds right Im in Spain, Is it not possible to convert them to rear suspension with a kit? Ive just bought the Giant Dirt E 3 for 1799euros its a hardtail
Thanks for the info. I’ve just purchased a full sus.
Above bike still for sale.
Yes it's beautiful
I'm new to e bikes although I've got 2 now , buy have you thought of buying your own motor with wheel and battery for s bike and going a lot faster?
I live in a very quiet area, Spanish countryside, nearest bar 7 kms
Probably convert one for 150 motor with wheel etc and 220 Panasonic battery
Yes it's beautiful
If you want to go a lot faster and convert any bike to an E-bike, then paradox kinetics do a throttle motor, called the Hermes. It’s 1500W. They’re based in Greece, and I got a quote off them for the entire conversion kit for £2350. I would urge you not to break any laws in your country, but if you use it on private land, then I don’t see a problem. I figured you were going to de-restrict anyway, that’s why I posted.
yes I know over 250 w is a bit naughty but you can register them as mopeds, then have to get a homogulation test, right mirrors , indicators ,lights etc. EU is 250w US I believe is 500w many of these wheels sold with motors are 100w but there 1500w and even 250w
Thats a high price to convert, on ebay you'll find a wheel with motor and controls, btrain all you need apart from battery theyre from about 200 euros so you have the kit for 350
    672K
