700wh battery
Munsen Weegie
Luton
What's the furthest you've ridden on a single charge? Do you think it's possible to squeeze 100kms out of the 700wh battery?
I‘m 77 kg, ride mainly ECO (15/30%) and a little TRAIL (30/60%) und can go about 100 km and more than 2.000 m elevation gain - and 10% juice is left.
Today I rode the Yorkshire True Grit ride on the North York Moors and when I finished I had covered 44.2 miles and climbed 4118 feet and when I checked the battery remaining it was at 28% which I thought was really impressive and mine is the 704wh battery.
on fairly flat, roads, in eco mode, I can get 70kms out of my 378wh Focus battery (and I weight 114kgs). in other words the answer to your question is "Yes, but it depends....."
My usual ride is 50-60 km with 1000+ elevation gain and I normally come back with about half of the battery left, may be just a touch less. Lately, I stopped charging the bike before each ride, especially when I plan to do something shorter than 50 km.
I think its possible to get 100km with 500w battery. and sure its going to need some effort from the person riding the bike also ;)
Today rode 73km with 15% battery left. 500w Levo 2019.
And I weight 92kg at the moment. Going for 82 to get some more range ;)
-K
Just got back from the Coast2Coast ride and we’ve concluded it comes down to rider weight and elevation gain more than mileage.
Typically for me at 103kg All Up Weight I got 40miles and 5000ft of climbing..Final day was 36miles and 2700ft climbing and 4 bars left..
Lighter guys were getting more..
On an Expert with a 700wh battery.
Thats an interesting discussion. I had the same thoughts and wanted to do some testrides. I do have the Levo 2019 Alu Comp with the 500w battery. Today I did a 100KM ride with 850hm. I set Eco to 20/35. It took 74% of the battery so I came back with 26% left. I had an everage speed of 21km/h and rode quite often above 25km/h. I used the Eco mode in approx 99% of the ride. 20/35 Eco mode does feel a bit to "hard" for me though. Maybe 25 or 30/35 would be a bit more smooth. However iam impressed. Iam 80KG and so so fit.
Maybe that info helps.
  • Hot
Reactions: Koo
What means "so so fit" if you can push it over 25kmh... 80kg with kit? anyways those Kilometers are completely possible if your are fit and light. preferably both.
-K
Speci-Levo-S-Works, 700Wh
I did a ride at home:
Start - battery: 100%
3 hours
45 km
1100 hm
End - battery: 57%
Seems I could go 6 hours, 100 km, 2000 hm with one load of 700 Wh.
Eco 15/30%, Trail 30/60%, Turbo 60/90%
Details see here:
Mödling Radfahren
    670K
