Coil Shock for Focus JAM2 (Gen1 - Shimano)
8,664
I have never ridden a bike with a coil shock, but I would expect a coil shock on the Focus Jam2 to have the same advantages/disadvantages as if you fitted it to a Focus Jam, or indeed any other similar travel/type of bike. :)
  • Like
Reactions: Gio
sputnik275wce
24
18
Switzerland
Thanks for the answer! Unfortunately its not that simple. It depends on how much the bike is build for linear or progressive damping. ?
Eckythump
832
680
North Yorkshire
Not sure how it will work on a Jam2 with the suspension design initially being digressive to the sag point then progressive for the rest of the travel. Might be a bit mushy until it ramps up.
8,664
A very good point! As I said, I've never ridden a coil shock. With the Focus Jam2, I find that I am going through the shock travel much more than I would expect when compared to the fork travel. On my last three clockwork bikes I have had an imbalance of that sort between fork and shock. Sometimes it was the fork that was not progressive enough, sometimes the shock. Either were easily fixed by the use of spacers to alter the volume of the air spring. But with the Focus, I'm taking my time before doing anything to the shock. On almost every ride I'm finding the stanchion "O" ring right at the end of the travel. But so far I haven't felt any bangs or any other bottoming out symptoms. What I do believe is that because the shock is sitting into its travel a lot more than the fork, the bike orientation makes steep climbing harder and occasionally impossible. Making the shock more progressive and therefore more supportive would solve that problem.
Focus say this:
"The linkage is designed to give a digressive rate until the sag point at 30%; then the stroke becomes progressive until the end of the travel. This is said to give sensitivity at the beginning of the stroke to gain grip, and then ramp up to provide support during the mid-stroke, as well as to prevent bottoming-out on bigger hits."
I don't experience the "ramp up to provide support during the mid-stroke" but I do notice the "prevent bottoming-out on bigger hits."
Olly Wilkins has a coil on his analog Sam, saw him riding it at Peaslake last week. He is sponsored by X-Fusion, so may be one of these? Or more likely a prototype:
VECTOR HLR
MRP Hazzard is available with progressive springs, and is designed for bikes where a linear coil would not be ideal.
Hazzard
Heres is OW's bike
sputnik275wce
24
18
Switzerland
Focus say this:
Focus say this:
My ring is always completly at the bottom of the stanchion. I also put some more psi into the damper. It got poppier but the ring is still all the way down.
sputnik275wce
24
18
Switzerland
VECTOR HLR
Hazzard
Thanks! I will have a look at the mrp hazzard??
Eckythump
832
680
North Yorkshire
Have you added any volume tokens? I put in 2 of a possible 3 to get it how I wanted. A lot cheaper than a new shock.
Keisari66
57
28
Finland
Decided to get the dbcoil inline. Now I don’t know what the eyelet size should be, there’s open eye 15mm too but I don’t think that’s what I need. The size is 210/55 with 25x8mm hardware right?
sputnik275wce
24
18
Switzerland
You should ask Focus directly, they always gave me satisfying answers...
Keisari66
57
28
Finland
Bumped into a problem :| Cane Creek DBinline coil with valt 2.25” spring and after install it’s touching the frame... what’s the next step?
khorn
980
1,054
Denmark
Actually when it gets compressed it moves further away from the frame.
Agree with regards to the leverage factor, however when you compress a spring it will expand a bit sideways and/or even go into a slight arc.
That setup will rub the frame for sure but it’s your bike and it’s a free world so do whatever you like ;)
Karsten
  • Like
Reactions: S D
