Emilio-Megamo Reason
Hi Greg!
I recently installed a new Fox DHX2 coil shock on my Megamo Reason AL ( 160 mm travel) . The bike shop recommended a 650–700 lb spring because I weigh around 103 kg (227 lbs) fully geared up.
After installing the 700 lbs shock, I checked the sag and measured approximately 22 mm. Since the shock has a 55 mm stroke, that works out to about 40% sag, which is much higher than the 28–30% range I'm targeting.
I've used several online spring calculators, and most of them suggest either a 700 lb or 750 lb spring for my weight and bike setup. However, based on the sag I'm seeing, there seems to be a large gap between the recommended spring rates and the sag I want to achieve.
Because of this, I ordered the stiffest spring Fox offers, an 800 lb coil. What I'm trying to understand is why my bike appears to require such a heavy spring rate. On other bikes I've owned, a 650 lb spring was typically sufficient for my weight and riding style.
Is there something about the Megamo Reason AL's suspension kinematics or leverage ratio that would explain why I need a significantly stiffer spring than expected?
