If you need a rock guard you’re doing it wrong IMO. However I do recommend you protect the frame with a RideWrap or equivalent.Just purchased a Levo 4 Expert, do you need a rockguard ? my Gen 3 needed one as the platic guard was a little fragile. If one needed any other options to Protect emtb?
I broke a gen 3 plastics when a rock pinged off the front wheel, sometimes there is no avoiding hitting that area. I will take a look at RidewrapIf you need a rock guard you’re doing it wrong IMO. However I do recommend you protect the frame with a RideWrap or equivalent.
From what i can see RideWrap is a alternative to Invisiframe not a rock guard / bash guard.I broke a gen 3 plastics when a rock pinged off the front wheel, sometimes there is no avoiding hitting that area. I will take a look at Ridewrap
I don’t see the oem cover as something I need to protect. It’s essentially an inexpensive sacrificial part. The Gen 4 oem cover isn’t so brittle that a rock kicking up will break it anyway.I broke a gen 3 plastics when a rock pinged off the front wheel, sometimes there is no avoiding hitting that area. I will take a look at Ridewrap
