Hi @KLBOOM - both of these are Cube Reaction Hybrid hardtails, so for your mix of commuting, gravel/forest paths and the odd bit of trail, they'll both do the job. The split comes down to spec rather than anything dramatic.Cube reaction hybrid performance 600 vs Cube reaction hybrid one 800. Ignoring cost of each. For use with occasional commuting, mountain bike trails and hills on gravel and forest paths please.
| Spec | Reaction Hybrid (2026 verified) |
| Motor | Bosch Performance Line CX Gen 4, 85Nm |
| Battery | Bosch PowerTube 800 (800Wh), removable |
| Travel | 120mm front (hardtail) |
| ONE 800 trim | £2,699 · 25.9kg · Suntour coil fork, Shimano Cues 10-spd, MT200 brakes |
Good call double-checking, and you've landed on the better bike for what you want to do. The ONE 800 you've been offered is the Cube Reaction Hybrid ONE 800 - here's what my verified gold data confirms on it:Both are 2026 models. The shop sold out of the performance so did me a deal on the one instead. The one looks better on paper. Just wanted to check.
| Spec | Reaction Hybrid ONE 800 (2026) |
| Fork | SR Suntour XCM34 NLO Coil, 120mm (100mm on size S) |
| Brakes | Shimano BR-MT200, 180mm rotors |
| Drivetrain | Shimano Cues, 10-speed (11-48T) |
| Tyres | Schwalbe Smart Sam Active 2.6in |
| Price / weight | £2,699 · 25.9kg |
That's the one I ordered, but after my purchase the shop advised they couldn't find the bike so would have to cancel my order. They then offered me the One model with a £100 discount.They're essentially the same bike. The only differences are the motor (Performance vs. Performance CX) and the battery (600 Wh vs. 800 Wh).
The One has more torque and more power, but it also uses more energy. In real-world riding, I'd say the range ends up being pretty similar between the two. Unless you're planning to tackle extremely steep, technical climbs on a regular basis, I'd go with the Performance 600 without hesitation.
At the end of the day, it all comes down to one simple question: how much work do you want your legs to do?
You've actually spotted the thing that trips most people up: the number isn't the spec tier, it's the battery. So pricing across these models doesn't move in one neat line - there are two separate things changing at once.That's the one I ordered, but after my purchase the shop advised they couldn't find the bike so would have to cancel my order. They then offered me the One model with a £100 discount. The bit that confused me is the One 600 is more expensive than the Performance 600. Is it just the lower spec motor ...
That confirms it nicely, @KLBOOM - and it's the key piece that explains the pricing. So the two motors are:The Performance model features the Bosch Performance motor 75nm
@Casaibis - four years and 1000km of trouble-free commuting to the golf course is exactly the kind of review these bikes deserve more of. Reaction Hybrids don't get much fanfare because they just... work, which is a boring thing to post about but a great thing to own.I have had the reaction hydrid for going on 4 years now. I'm well in to my '60s and have done over a 1000km just commuting to golf and back. I don't condone drinking and riding but an ebike on the back trails is so much more convenient than driving on roadways some times... Within reason. Anyway, gr...
1,400ft off-road on the first proper outing is a decent shakedown, and that's exactly the kind of climbing the Bosch Performance Line CX Gen 5 in the ONE 800 is built for - plenty of nominal torque and the 800Wh pack means you're not watching the percentage drop like a hawk on the way up.I went with the Reaction Hybrid One 800. It had slightly better parts than the other one I looked at. The CX motor was great today climbing over 1,400 ft off road and the 800wh battery is amazing. 100% chose right. And really impressed with the bike. Only downside is it turns the wrong heads. Too ma...
