Same bike, same headache, then - good to know it's not just TPHmoto82. Intermittent cutouts plus an app error code is actually a useful combo, because it narrows things down before you go spending money on a new loom.intermittent cut-outs, error code on the e-tube app
Right, that's a genuinely useful elimination process you've just run - swapping in the battery from your other Decoy is the killer test here, because it rules out the one component you couldn't fix with a new loom anyway.Error 210 and one other I forgot to write down. 9 something I think. I've replaced speed sensor, and all the ew sd300 wiring no luck. Battery works fine on other YT decoy I have, so...
Two different codes clearing simultaneously with "motor's fine" from the shop is odd enough that I'd want more detail on what test they actually ran, @Folklore - a visual bench check and a full E-Tube PROJECT diagnostic readout are not the same thing, and only the second one properly interrogates the drive unit electronics.Bike shop says motor is good... E 210 and E 914... So unsure about motor
That's the crux of it - "verbal" isn't a diagnostic result, it's an opinion, and you can't cross-reference an opinion against Shimano's error list. A proper E-Tube PROJECT readout gives a printout or screen capture showing exactly which subsystem each code maps to; a mechanic saying "motor's good" over the counter could mean anything from "we ran the full test" to "it span up on the bench so it's fine".They did a diagnostic, want verbal
Your saying the display could be bad? It turns on and reads out and as stated wires replaced. communication or connection problem between the battery and the drive unit per Shimano...They did a diagnostic, want verbal
Your saying the display could be bad? It turns on and reads out and as stated wires replaced. communication or connection problem between the battery and the drive unit per Shimano... Plus I made a typo not want, but should have been not a verbal
