De$lo(
Just for the sake of clarity, if you run out of battery does that make these bikes unridable being that they have no physical gears to actually change?
I read that they will have a limp mode - like they do now as a reserve and for AXS shiftingJust for the sake of clarity, if you run out of battery does that make these bikes unridable being that they have no physical gears to actually change?
Who knows, there isn't a production bike yet, but seems likely they will still have a means for changing gear when the motor cuts.Just for the sake of clarity, if you run out of battery does that make these bikes unridable being that they have no physical gears to actually change?
He has a great point, however he seems to be talking about the Rivian bike which is a "dynamo" and not a direct drive, more "Pedal by Wire".He has a point
Hmm, Alex Bike Tester did say it may be a “door opener to cheaper bikes“ which may reduce the cost of higher-spec bikes too. Nothing wrong with that, right?Just my opinion, but yes I think these will have an important place in the emerging high powered Class 2+ e-bike segment and I think they make great sense. But I think they will be relegated to that segment of the market ultimately due to lower efficiency, larger batteries & higher weights.
I'm glad that he spent time describing the feel of the motor at the pedals; that it felt more response in boost mode implies that there's more software tuning to be done, which is easier to pull off than fundamental mechanical gear changes. Clearly Rob was more blown away than Alex and if I had to place bets, it's no surprise who's opinion I'd trust more.
Ride feel starts at 3:30.
It's going to be fun to watch for sure.
Think of the All Mountain light e-bike market as like the Mazda Miata Manual transmission of the e-bike market. Built more for high engagement, maximum involvement and back to the basics.
Kinda.He has a point
What have you heard ?So far it's killed the Pinion MGU, let's see how long the cassette/derailleur manufacturers can stay alive. There will always be a place for derailleurs in the future, but a much smaller one?
scooterhelden.de
