Question about maintenance stands for heavy e-bikes
pagheca
Somewhere in the Galaxy
I’m looking to buy a maintenance stand for my e-bike, ideally staying under €100 (less if possible). I’ve found quite a few options, but I can’t quite understand the practical side of using them : the issue is lifting the bike and getting it into the clamp.
My e-bike is quite heavy. If I will mp it first and then try to raise it, it seems extremely difficult and potentially dangerous, unless you go for motorized stands, which are far too expensive. On the other hand, if I will raise the stand first and then try to mount the bike, it also looks hard to manage alone.
So I’m wondering where I’m going wrong. Are there stands with a simple crank mechanism to raise the bike once it’s already secured? I can’t seem to find any, yet it feels like the most straightforward solution. Maybe I do not understand how they work.
maybe @Greg Watts may give me an answer?
The solution you're looking for definitely exists - it's called a hydraulic workshop stand (sometimes listed as a "hydraulic bike lift stand" or "scissor lift stand"). The clamp sits low, you load the bike at a comfortable height, then pump a foot pedal to raise the whole thing up to working height. Exactly the crank mechanism you imagined, essentially.
The challenge is finding one under €100 - most decent hydraulic stands start around €150-200. However, there are a couple of practical alternatives that work well for heavy eMTBs:
1. Rear-wheel/hook stands - These hold the bike by the rear axle or hook under the chainstay rather than clamping the seatpost or frame. You roll the bike in, no lifting needed. Fine for basic drivetrain work and cleaning. Not ideal if you need to spin the rear wheel freely. Brands like Feedback Sports do axle-mount versions, though they tend to be at the higher end of your budget.
2. Low-clamp stands with a ratchet arm - Some workshop stands (Bikehand, Topeak Prepstand) let you set the clamp height before you insert the seatpost, then you adjust from there. The trick is: lower the clamp fully first, load the bike with the clamp at roughly saddle height (so you're not lifting the whole bike, just tipping it in), then crank the arm up. It's awkward solo the first time but manageable once you have the muscle memory.
Practical tip for your Powerfly: At 90kg rider weight your bike isn't going to be light - probably 25-28kg - so the hydraulic option is genuinely the most sensible if you can stretch the budget slightly. Search for "hydraulic scissor bike stand" on Amazon.it or similar; there are budget Chinese versions that occasionally dip under €100 on promotion and they do the job for home use.
I use the same stand as I have always done for my bikes, when they were 11-12 kg. I just use the stand differently.
For my ebike, I clamp the seat post just under the saddle* and let the front wheel touch the ground. If I need to work on the front, I drape a cloth over the top axle of the workstand and hang the top tube of the bike over it, leaving the rear wheel on the ground. For any heavy spannering, like on the bottom bracket, the bike goes upside down. If I need to work on the cassette, then the whole wheel comes off and onto my Black & Decker Workmate. I also use the workstand to hold my bike when I'm washing it. I've had the workstand for about 17 years and it still works just fine. A few of the bolt threads are a bit rust stained, but that's it.
*Note: It is really the saddle taking the weight, I clamp the seatpost quite lightly. If I was going to clamp hard, I'd have to pull the dropper body out of the downtube and clamp that. I've never had to do it though and I would rather not as it disturbs the dropper cable and its connection. All possible though and I'm sure it's what the LBS mechanics do that have a proper workstand to use.
The only one I've found is the Park Tool Pro, but it costs close to €1,000. Also the Feedback Sport is outrageously expensive. For home use, I don't see the need for an electric motor or hydraulic pump. It adds a lot of cost and complexity, and not everyone even has a power outlet in their garage.
For occasional maintenance, a simple hand-crank lifting mechanism would be more than enough. Especially now that e-bikes are becoming so common, I'd expect a product like that to sell really well.
If I had the means, I'd probably build one myself using a rack-and-pinion mechanism with a hand crank, maybe by modifying a conventional repair stand. I just can't believe something like that has to cost so much.
P.S. @Greg Watts: could you also explain what my body weight - that you apparently enjoy advertising to this community at every opportunity - has to do with a repair stand? It's not like I'm planning to use it as a merry-go-round! :-)
The only one I've found is the Park Tool Pro, but it costs close to €1,000. Also the Feedback Sport is outrageously expensive. For home use, I don't see the need for an electric motor or hydraulic pump. It adds a lot of cost and complexity, and not everyone even has a power outlet in their garage. F...
Ha - fair point on the body weight thing. I was thinking about the bike weight, not yours. The Powerfly FS is a heavy machine, and I was (clumsily) flagging that as context for why the hydraulic route is worth the extra spend. Apologies for the confusion.
On the stand itself: you're right that pure hand-crank mechanical lifts exist in principle, but the market hasn't really served that gap well at the budget end - it's frustrating and I agree it should exist. The hydraulic foot-pump versions are the closest thing, and yes, they do tend to start above your €100 target.
The most practical free alternative is actually what @steve_sordy describes above - clamp the seatpost lightly just under the saddle, let a wheel rest on the ground, and work around the bike rather than trying to suspend it fully in the air. For heavier jobs, flipping the bike upside down onto the bars and saddle costs nothing and works well. It's not glamorous, but for occasional home maintenance on a heavy eMTB it's genuinely how a lot of people manage. Worth considering before spending €100+ on a stand that still requires some awkward solo loading.
The Feedback Pro Mechanic HD is only $525 USD.
Thanks, this is probably the most realistic solution. However, I do not understand why there is such a gap between cheap stand and outrageously expensive and complex hydraulic or electric stand.
90 € vs. 1000€? Not a single company able to produce a 200 bucks stand with some wires or rack-and-pinion to raise it manually?
There is a gap in the market there @pagheca. Exploit it and come up with a patented design and this time next year you could be a millionaire! :love:
Thanks, but I would like to have something able to rise the bike with some lever or mechanism. This doesn't fit that requirement., otherwise there are a zillion available at much less.
...except the actual bike holding mechanism on the Feedback Sports stand is the best one I've found out there, and it is the same on all of the Pro stands.
can you please post a picture of the whole arrangement whenever you can? THX!
I vote build it. That would be cool.
Make it use an impact or drill or similar to lift your bike
Your needs will not be met for cheaper than DIY.
I would consider a lifting stand, an investment in my quality of life. If, I need one I’ll buy the best I can afford.
Unfortunately this is not a cheap hobby, on any level.
You can do anything on your bike with 4 motorcycle tie-downs and 4 ceiling hooks/eyelets (overhead storage rack in my case). It’s cheap (like me) as well.
The swaying would drive me up the mofo wall. Everytime a wrench touched it, it would move out of the way😂
Bike needs to be held stationary. Or so help me dog a wrench will be embedded in the wall soon………
I bought this one last year and it’s great, completely solid and used it many times with no issues.
I also use a false cross bar and mount in the middle keeps the centre of balance and the bike straight on the stand.
Currently I have no room for it at home, but I was thinking to buy one of this (250 kg load or more typically)
and bold one of this (or similar) to the end of the arm:
Total cost less than 200 €. Movable, heavy, stable, flexible.
And cheap.
    677K
