Avinox Ride App Sync Issue – Ride Summaries Sync, Detailed Ride Data Fails After 24/05
Maxi
Cumbria
Hi Greg
Problem​
My bike is recording rides correctly, and the Avinox Ride app is receiving the ride summaries, but I cannot download the detailed ride data.
Symptoms​
  • Last ride that fully syncs and opens correctly in the Ride app: 24/05
  • Every ride after 24/05 appears in the Ride History list on the phone
  • Ride summaries are visible, including:
    • Date/time
    • Distance
    • Location
  • When I tap any ride after 24/05 to view the detailed data, the app shows a failed-sync style icon and never downloads the ride details
  • No map, elevation profile, power data, calories, mode usage or other detailed ride metrics are available
What Still Works​
  • Bike records rides normally
  • All rides are visible in the bike's ride history
  • Bluetooth connection works
  • Bike is connected to the Ride app
  • I can change and save custom assist mode settings (e.g. Auto mode settings) from the app
  • Battery and bike communication appear normal
Bike / App Information​
  • Bike: Amflow PL Carbon Pro
  • Firmware version: 01.03.01.27
  • Phone: Android
  • Ride app: latest version available
  • Bike firmware and app are both kept up to date
Troubleshooting Already Tried​
  • Deleted Bluetooth pairing and re-paired bike
  • Cleared Ride app cache
  • Confirmed app and bike are on latest versions
  • Confirmed bike and app still communicate correctly (settings can be changed from the app)
Additional Information​
  • The first ride that fails is the ride immediately after the last successful ride on 24/05
  • Every ride since then behaves the same way
  • This makes me wonder if a corrupted ride file could be blocking the sync queue
Based on the symptoms, the most significant clue is that the ride immediately after 24/05 is the first failure and every subsequent ride also fails, while bike-to-app communication continues to work normally. That points more toward a stuck ride-processing or sync-queue issue than a Bluetooth problem.
Hi Greg Problem My bike is recording rides correctly, and the Avinox Ride app is receiving the ride summaries, but I cannot download the detailed ride data. Symptoms Last ride that fully syncs and opens correctly in the Ride app: 24/05 Every ride after 24/05 appears in the Ride History list on the p...
@Maxi - good write-up, that's a well-isolated fault report. Let me summarise where things stand and what I think is going on. Thread Summary: Avinox Ride App - Ride Summaries Sync, Detailed Data Fails After 24/05
What's happening
Maxi's Amflow PL Carbon Pro (firmware 01.03.01.27) is recording rides fine and the app is clearly talking to the bike - settings changes push through, Bluetooth is solid. The problem is surgical: ride summaries (date, distance, location) appear in the history after 24/05, but tapping any of them for detailed data - map, elevation, power, cadence, calories, mode breakdown - returns a failed-sync icon and nothing ever downloads.
Everything before 24/05 works. Everything after 24/05 fails. Same pattern, every ride, without exception. What's already been ruled out
• Bluetooth connection - still functional (settings sync works fine) • App/firmware being out of date - both confirmed current
• App cache - cleared, no change • Pairing issue - deleted and re-paired, no change
So it's not a comms problem between phone and bike. The bike is talking to the app just fine - it's specifically the detailed ride file download that's broken.
The most likely culprit Maxi's own read of this is solid: the sharp cut-off at one specific ride points strongly toward a stuck or corrupted entry in the sync queue, not a general connectivity fault.
The Avinox system is designed so that ride data syncs automatically to the app after each ride - and the drive system records comprehensive ride data which is then synced to the app after the ride. The summary metadata clearly gets through; it's the full ride file that's stuck.
The working theory is that the first ride after 24/05 either recorded a corrupt or malformed file, and that file is now sitting at the front of the transfer queue blocking everything behind it. The app sees the entry exists (hence the summary), but can't parse or download the full payload.
What to try next 1. Check if the Avinox app has a "delete ride" function on the bike side - Avinox did add ride deletion support in a firmware update ( one release added support for deleting ride data). If you can delete the first failing ride (the one immediately after 24/05) directly from the bike's display or the app, it may clear the queue and let everything behind it flow through. Worth trying before anything more drastic.
2. Check your Ride Data Backup / Cloud setting - once enabled, ride data can be synced and backed up using the mobile network, and the synced data can be viewed on other devices by logging into the account. If you have this enabled, the data may already be on Avinox's servers even if it's not rendering in the app - worth logging in on another device to check. Also worth confirming this setting hasn't been toggled off around the 24/05 date, which could explain the clean cut-off.
3. Contact Amflow/Avinox support directly - this one may need a server-side fix or a log pull.
The Avinox Ride app has had known display and feature issues reported by users, and the support team has been responsive on here. @Amflow_Support's post shows they're active on the forum - drop them a DM with your firmware version and the exact date of the first failing ride, and reference this thread.
What this isn't It's not a Bluetooth fault, not an out-of-date firmware issue, and almost certainly not a hardware problem. The bike is fine. This lives entirely in the sync/data layer - which is actually the better outcome, because it means the ride data is almost certainly still on the bike waiting to be retrieved.
Cumbrian trails presumably aren't going anywhere while you wait for the fix. 🏔️
So there is no option to delete a ride on the bike. I deleted the first 'failed' one on my phone but still won't allow me to download data from later rides.
@Maxi - so deleting the entry on the phone side didn't clear the queue. That's actually useful information: it confirms the blockage isn't just a bad local entry on the phone - the issue is almost certainly server-side or in how the Avinox backend is managing your sync state.
At this point the sensible next move is to go straight to Amflow support. You've done the logical troubleshooting steps and they're not shifting it. This needs someone with access to your account's sync logs on the backend.
What to send them: • Firmware version (as you have it)
• The exact date of the first failing ride (25/05 or whenever it was immediately after your last successful sync) • Confirmation that deleting the phone-side entry made no difference
• That all bike-to-app communication otherwise works fine (settings push through, Bluetooth solid) @Amflow_Support's post shows they're active on here and responsive - worth a DM with those details and a link to this thread so they have the full picture without you having to type it all again.
One other thing worth checking before you do: if you have cloud/backup sync enabled in the Ride app, log in on a second device (or the web if there's a portal) and see whether the ride data is sitting on the server already. If it is, that's actually a good outcome - the data exists, it's just not rendering locally - and it's also useful diagnostic info for support.
FYI - if you login to Avinox Antriebssystem - Power Your Ride - Avinox there is no option to show your synced / cloud data
@Maxi - good to know, and that's a useful data point. The avinox-ebike.com homepage is marketing-only - no account portal, no ride data dashboard visible from the page you've linked. So the "cloud backup / view on another device" suggestion I made earlier doesn't appear to have a web interface to go with it, at least not one that's publicly accessible from the main site. Worth noting in case there's a hidden login somewhere, but I wouldn't spend more time hunting for it.
That basically closes off the self-service options. At this point you've exhausted what can be done from your end: • Deleted and re-paired Bluetooth - no change
• Cleared app cache - no change • Deleted the first failed ride entry - no change
• No web portal to check server-side data This needs Avinox/Amflow support with actual access to your account's sync state on the backend. Drop them a message with your firmware version (01.03.01.27), the date of the first failing ride, and a link to this thread - saves you typing it all out again. Their support has been responsive based on what members here have reported.
Not much more to pull from this end without backend access, unfortunately. The bike's fine; the data's almost certainly sitting there - it just needs someone with the right tools to unstick it.
DM sent to Amflow support so if they respond, will post back here to help you learn :-)
@Maxi - perfect, that's exactly the right move. You've done everything that could be done from your end, documented it clearly, and now it's in the right hands.
Appreciate the offer to report back - genuinely useful for anyone else who hits this on an Amflow or Avinox-powered bike down the line. The sharp cut-off at a single ride date is a pretty distinctive symptom, so a thread with a confirmed fix will be worth its weight.
Hope they sort it quickly. Tag me again any time you need a hand. 👍
Hi, i habe the exact same problem. And still have not found a solution.
@Freeridernbg - you're not alone. This seems to be a fairly widespread issue affecting Avinox Ride app users, with ride summaries syncing fine but detailed ride data failing to download - and from what's been discussed in this thread, it appears to have started around 24 May.
The short version of where things stand: • It's not a user-side fix - deleting the failed ride entry on the phone doesn't clear the blockage, which points to a server-side or app-side queue issue rather than anything wrong with your setup
The avinox-ebike.com portal doesn't offer a ride data dashboard, so there's no way to verify or manually clear synced data from the web
Best move right now: Contact Amflow/Avinox support directly. A DM or support ticket with the date your sync broke and a description of the symptoms (summaries sync, detail data fails) is the most useful thing you can do
If you get a response from support with a fix, please do post it back here - a few of us are watching this thread and it'd be genuinely useful for everyone hitting the same wall.
Avinox released a new update yesterday to correct known errors (01.03.0219).
@Albertocsoares - that's exactly the news this thread needed, cheers for flagging it. I can't independently verify the specifics of version 01.03.0219 or what issues it covers from my end, but heads up - according to Albertocsoares, this update does NOT fix the ride recording issue. There's still a bug where ride activities disappear after pressing 'Stop and Sync' on M1 devices, so don't get your hopes up just yet.
For anyone following this thread with the same problem (summaries syncing fine, detailed ride data failing to download): • Update the Avinox Ride app and check you're on the latest version
• If the update resolves the detailed data sync, worth posting back here to confirm • If it doesn't, the Amflow/Avinox support route remains the right call
@Freeridernbg - worth trying the update if you haven't already, but be aware it may not solve the disappearing activities problem. @Albertocsoares - did anything at all improve, or is it a complete miss?
EDIT: Corrected the post - version 01.03.0219 does NOT fix the ride recording issue; ride activities still disappear after pressing 'Stop and Sync' on M1 devices. Thanks @Albertocsoares for the heads up.
I just tried the new version on my M1, and unfortunately it still has the "new" issue where it doesn't record your rides anymore. After you finish a ride and press "Stop and Sync," the ride activity disappears.
I guess they were more concerned about making sure the new bikes didn't show the "wrong battery" at Eurobike than fixing the other "minor" issues.
I just tried the new version on my M1, and unfortunately it still has the "new" issue where it doesn't record your rides anymore. After you finish a ride and press "Stop and Sync," the ride activity disappears. I guess they were more concerned about making sure the new bikes didn't show the "wrong b...
@Albertocsoares - so the update fixed one set of bugs and introduced a different one. Classic firmware bingo.
The "Stop and Sync → ride disappears" issue is a new regression then, distinct from the original sync problem in this thread (summaries arriving but detailed data failing to download). So you've now got:
Original issue (post-24 May): Ride recorded, summary syncs, detailed data won't download • New issue (post-01.03.0219): Ride data vanishes entirely on "Stop and Sync" - nothing recorded at all
That's arguably worse. At least before you had the summary. Your read on the Eurobike prioritisation is... not unreasonable. Getting the battery display right on new hardware in front of press and buyers is the kind of thing that lands on someone's desk as P0. Ride logging for existing M1 owners? Apparently P2 at best.
Best thing you can do right now is report the regression to Amflow support explicitly - make clear this is a new bug introduced by 01.03.0219, not the original sync issue. The more precisely it's scoped, the faster it gets routed to whoever actually owns the recording pipeline.
@Freeridernbg - given the above, probably worth holding off on the update until Avinox push a follow-up. The original bug is bad; losing the ride entirely is worse.
I installed the Update yesterday and did a test ride with no success. I did not even see the ride in the App. So today i did another ride and surprisingly the ride was tracked and shows up in the App and i can See all the Details. So it is working again now.
@Freeridernbg - brilliant, that's the best update this thread's had all week.
So the pattern seems to be: first ride after the update didn't register at all, second ride came through fine with full detail. Sounds like the update needed one full sync cycle to settle - a bit of "have you tried turning it off and on again" energy, except the bike does it for you on the second outing.
Really useful to know. @Albertocsoares - worth trying another ride if you haven't already, rather than writing the update off on the basis of the first attempt.
    676K
