@INVISIBLE - short answer: nobody's done it, and there's a good reason for that. Bosch and Yamaha motors have entirely different mounting systems, frame interfaces, bottom bracket designs, electronics architectures and wiring harnesses. They're not just "different shaped things in the same hole" - the whole frame is designed around one or the other from the ground up. There's no documented case of a cross-brand motor swap into a PW-ST housing/shell, and I haven't been able to find any evidence of it happening in the wider community either.Has Anyone Been Able To Fit A Bosch Or Other Motor In A Yamaha PW ST Housing Or Any Other Brand Motors Modify Housing Brackets Etc
You've now asked about three things across the thread - the Bosch swap, and the differences between PW-SE, PW-TE and PW-ST. Let me take the new question directly, since it's the one I can be most useful on.PW SE And PW TE And PW ST Differences
