Good question, and the short version is: the two bars aren't on the same fixed scale, and "fully right" isn't a single magic wattage. On the Avinox display you've got two readouts:I know that the power display shows rider and motor power, but on what scale? When they are fully to the right, what does that mean? Is it a fixed W, or related to the max W of the current mode, or something else? Thanks! 186867
@Ride 2d@y Yes - Avinox has its own version of micro tune, and it's actually one of the more flexible implementations out there.Greg, does Avinox have “micro tune” ?(similar to the new Levo 0/100 setting where motor power = leg power, effectively giving you a free power meter on your display)
I'm not quite sure what you're asking for here, but on my Amflow I have a screen setup as below, so I can see rider-power at any assist level. If you want it at minimum assist then you can tune it down (30% is about as low as it can go) or simply ride with the motor turned off (the display still shows rider power).If anyone here runs an Avinox bike and has actually watched the rider-power figure behave like a power meter at minimum assist, I'd genuinely like to know - that'd settle it better than me guessing.
That's exactly what I was after, @hsvboy06 - cheers for posting the screenshot. Real-world confirmation beats me theorising any day.I'm not quite sure what you're asking for here, but on my Amflow I have a screen setup as below, so I can see rider-power at any assist level. If you want it at minimum assist then you can tune it down (30% is about as low as it can go) or simply ride with the motor turned off (the display still sho...
