Will the rear wheel off my Merida eOneSIxty work on Santa Cruz Vala?
EMTB Pro
The rear wheel of my Santa Cruz Vala i out of commission and I have an event coming up on Sunday. I have been search9ng around and the quickerst idea is to swap in the rear wheel from my grand son's Merida eOne Sixty. T he hub width and axle diametre are the same, but I suspect that it will be the sensors that rule it out. The Vala is Bosch gen 5 and the Merida is Shimano EP8. Any comments or ideas?
The rear wheel of my Santa Cruz Vala i out of commission and I have an event coming up on Sunday. I have been search9ng around and the quickerst idea is to swap in the rear wheel from my grand son's Merida eOne Sixty. T he hub width and axle diametre are the same, but I suspect that it will be the s...
@steve_sordy - good thinking on the quick fix, and the axle/hub width compatibility is the right place to start. Let me work through the sensor question carefully, because that's where it gets interesting.
The short answer: it'll probably work, with one caveat worth checking. The Vala runs Bosch Smart System (Gen 5), which uses a magnet mounted at the valve stem / rim rather than a traditional clip-on spoke magnet. That's an important distinction - the speed sensor reads off the rim, not the spokes. So if your grandson's Merida wheel doesn't have that Bosch rim magnet fitted (it won't - EP8 uses its own sensor arrangement integrated into the motor/chainstay area), you'll need to transfer or source a Bosch rim magnet before the Vala's system will see the wheel spinning.
The good news: those Bosch rim magnets are inexpensive and widely available - a few pounds at most Bosch dealers. You'd just need to fit it to the correct position on the rear rim before Sunday.
The checklist for the swap: • Hub width and axle diameter - you've confirmed these match ✓
• Cassette: the EP8 wheel will have a Shimano freehub; check the Vala's drivetrain cassette will fit (SRAM XD vs Shimano HG/Micro Spline - depends on your Vala trim)
• Bosch rim magnet - needed; fit to the new wheel before riding • Rotor: check the rotor is the right diameter and fits your brake caliper
What's the drivetrain spec on your Vala? That'll tell us whether the cassette situation is a problem or a non-issue.
The Merida has a Shimano transmission with an XT cassette. The Vala has a Sram 90 Eagle T- type transmission with SRAM XS 1275 Eagle T-Type. Al is 12-speed.
@steve_sordy - that's the wheel swap dead in the water then, unfortunately. The cassette incompatibility is the dealbreaker. Your Vala runs SRAM Eagle T-Type Transmission - that XS-1275 cassette requires an XD driver body on the freehub. The Merida's EP8 wheel will have a Shimano Micro Spline freehub (for the XT cassette), and you simply can't mount an SRAM XD cassette onto it. Different spline pattern entirely, no adapter exists.
So the checklist now reads: • Hub width / axle - you've confirmed these match ✓
• Bosch rim magnet - transferable, minor job ✓ • Cassette - hard stop. SRAM XD vs Shimano Micro Spline freehub. Not compatible.
Your options before Sunday: 1. Source a replacement wheel with an XD driver - a long shot at short notice, but worth a ring round local shops today. A spare rear wheel with an XD freehub would let you run your existing cassette.
2. Swap the freehub body on the Merida wheel - if it's a Hope, DT Swiss or similar hub with swappable drivers, an XD driver body might be available same-day from a well-stocked shop. Worth checking what hub the Merida is actually running.
3. Honest fallback - is there a bike hire option at or near Sherwood Pines if the wheel situation can't be resolved in time?
What hub is on the Merida wheel?
Its a Merida Expert TR with microspline. Definitely a Shimano hub.
Why can't the T-type chain and mech work with a 12-speed XT Cassette?
Its a Merida Expert TR with microspline. Definitely a Shimano hub. Why can't the T-type chain and mech work with a 12-speed XT Cassette?
@steve_sordy - fair question, and actually a better one than it might seem. Let me unpick it properly.
The short answer is: the T-Type mech will work with a 12-speed Shimano XT cassette - but with a couple of caveats worth knowing before Sunday.
SRAM officially says their T-Type components are designed for the T-Type ecosystem, and on paper they don't endorse mixing. But real-world community experience tells a different story.
The T-Type mech works fine with a regular 12-speed cassette - members here are running it with Garbaruk and Shimano Micro Spline cassettes without drama.
One rider replaced a worn cassette with a Shimano XT 10-51 and XT chain, kept the T-Type derailleur, and it works fine - they just moved the jockey wheels in slightly towards the wheel using a half-millimetre washer behind each.
That's a pretty minor tweak. The one thing to be aware of is chain compatibility.
Running a Shimano chain with the SRAM T-Type chainring can be noisy - though swapping to a third-party chainring (like Burgtec) resolves that. For a one-day event though, a bit of noise is academic.
So the revised picture for the wheel swap is: • Hub width / axle - confirmed match ✓
Bosch rim magnet - needs transferring or sourcing ✓ (cheap, quick job) • Cassette - you'd run your existing SRAM T-Type cassette and chain on the Shimano Micro Spline hub... wait.
That's still the sticking point, Steve. You'd need to mount your SRAM T-Type cassette onto the Merida's Shimano Micro Spline freehub - and those are different spline interfaces. Your XS-1275 cassette requires an XD driver body.
An XD driver body is required for the XS-1275 cassette. The only way the mech/cassette cross-compatibility helps you is if you were willing to run the Merida's XT cassette with your Vala's T-Type mech - that combination can work, but you'd also need a Shimano-compatible chain, and your existing T-Type Flattop chain won't play nicely with it.
For a Sunday deadline, the cleanest path is still sourcing a rear wheel with an XD driver - or finding out if the Merida hub's freehub body is swappable. What's the hub brand on that Merida wheel?
As I said in post #5 Its a Merida Expert TR with microspline. Definitely a Shimano hub.
@steve_sordy - yeah, fair enough. We've been going round in circles a bit and the honest conclusion was always going to be "this wheel won't work without more faff than it's worth."
Renting or borrowing a wheel with an XD driver is definitely the cleanest path for Sunday. Given you're at Sherwood Pines, worth a call to the bike hire operation there - they may have something, or at least know who locally might. A quick ring round Nottinghamshire/Lincolnshire shops today wouldn't hurt either; a spare rear wheel with an XD freehub is the kind of thing a well-stocked dealer might have kicking about.
Good luck for Sunday - hope the Vala's back in action and the trail conditions are kind. Tag me again if you need anything else before then. 🤞
    674K
