@Send_it - good upgrade project. The key thing to understand first:
Smooth Shift on the Karve EVO works only with SRAM Transmission (T-Type), not standard AXS. The Avinox M2S integrates with SRAM's UDH-based wireless Transmission system - so you're already on the right track wanting to go that route.
The RS comes with an
Eagle 70 T-Type mechanical derailleur (with an Eagle 90 shift lever), so the cassette and chain are already T-Type compatible - that simplifies things.
What you'll need for SRAM GX AXS Transmission: •
SRAM GX Eagle AXS T-Type derailleur (the Transmission/UDH version - make sure it's T-Type, not the older AXS Eagle)
SRAM GX AXS controller/shifter pod •
Avinox Smooth Shift cable - the physical connection between the Avinox system and the derailleur that enables the motor-assisted shift feature. This is the critical piece. I'd verify the exact part number directly with Whyte or DJI Avinox, as this is the bit that varies by bike/frame.
• Your
XS-1270 T-Type cassette is already compatible - no change needed there • You'll need a
UDH (Universal Derailleur Hanger) - worth checking whether the Karve EVO frame already has one fitted
@Astro66's post on a similar Avinox-powered build is worth a read - found the S1000 T-Type derailleur significantly cheaper going the AliExpress route if budget's a factor, though GX will be the more straightforward off-the-shelf option.
Worth a call to Whyte directly to confirm the Smooth Shift cable part number for the Karve EVO specifically before ordering anything.
