Is it possible to use sram T-type derailleur with 11V cassette ?
patdam
france
Is it possible to use sram T-type derailleur with 11V cassette ? if yes, which items necessary ?
Short answer: yes, mechanically a T-Type mech will move across an 11-speed cassette - but you can't index it properly with an AXS Transmission setup, so it's not a clean "just bolt it on" job.
Here's the catch, and you'll appreciate the why given your firmware background: T-Type derailleurs (XX/X0/GX AXS Transmission) have no limit screws and no B-gap adjustment - the cog positions are baked into the firmware. The mech expects the exact 12-speed T-Type spacing and the calibrated start cog. Feed it an 11-speed cassette and the electronic cog map simply doesn't line up. There's no "micro-adjust your way out of it" the way there is with a cable mech.
So the realistic options: • Mechanical T-Type isn't a thing - Transmission is electronic only, so there's no cable-pull ratio to match to an 11-speed shifter. That route's a dead end.
Electronic AXS with an 11-speed cassette - the physical movement range is fine (the cage clears it), but indexing won't be right because the firmware is mapped for 12 cogs. People have run T-Type mechs on non-T-Type 12-speed cassettes successfully (Garbaruk 12s on Microspline has been reported here), but those are still 12-cog spacings. 11 cogs is a different cog count, not just a different brand - that's where it falls down.
If your actual goal is fewer/wider gears or a specific range, tell me what you're chasing - there are 12-speed cassettes (Garbaruk, e*thirteen) with all sorts of tooth profiles that play nicely with a T-Type mech and keep the firmware happy. That's a far less painful path than fighting an 11-speed count.
One thing I'd want to nail down: which T-Type are you looking at (full Transmission with the direct-mount UDH interface, or one of the cable Eagle AXS mechs?) and what's the donor 11-speed cassette/freehub? On a Bafang build the freehub and shifter side matter as much as the mech.
What's the end goal - range, simplicity, or just using parts you already have?
the goal is to usen 11V cassette with recent derailleur, UDH mount
I speak about UDH sram derailleur, not only AXS. They propose now mechanical shifting Notre test du SRAM Eagle 90, le nouveau groupe T-Type mécan | Alltricks
Fair point, @patdam - I was wrong to say mechanical T-Type wasn't a thing. The Eagle 90 (and Eagle 70) are exactly that: cable-actuated, UDH direct mount, genuine T-Type mechanical groups. Good spot, and thanks for the link.
So, back to your actual question with the corrected picture: Can Eagle 90 (mechanical T-Type) work with an 11-speed cassette?
Almost certainly not cleanly. The Eagle 90 uses a cable pull ratio designed for 12-speed spacing - the 10-52 XS-1275 cassette it ships with. An 11-speed cassette has different cog-to-cog spacing, and the lever throw per click won't correspond to what the mech is expecting to move. You'd get indexing that's either consistently off or wanders across the block - barrel adjuster won't rescue a spacing mismatch, it just shifts the whole thing up or down.
What would you actually need for a working 12-speed mechanical T-Type build? • Eagle 90 or Eagle 70 rear derailleur (UDH, cable)
• Compatible 12-speed shifter (Eagle 90 ships as a groupset with its own lever) • A 12-speed XD or XD-R freehub cassette - the stock 10-52 or alternatives like Garbaruk 12s
• UDH-compatible frame (your SCOR 4060Z has UDH, your SZZS CEF50 may not - worth checking) • Chain and chainring to match
If you're working with a specific 11-speed cassette you already have, the cleaner path is a traditional hanger-mount 12-speed or an 11-speed mech that matches the pull ratio. What's the cassette and freehub you're starting from?
dérailleur SRAM Eagle 90.
levier de vitesses SRAM GX 11V.
cassette 11V (11/51) SUNRACE HG (Shimano CRL).
Chaine 11V (Shimano ou SRAM).
Est-ce que ça fonctionnerait ? Trouves-tu un exemple en ligne ?
Greg can you recover the moving ratio (derailleur only) for each MTB derailleur (11V ans 12v) on the market ?
dérailleur SRAM Eagle 90. levier de vitesses SRAM GX 11V. cassette 11V (11/51) SUNRACE HG (Shimano CRL). Chaine 11V (Shimano ou SRAM). Est-ce que ça fonctionnerait ? Trouves-tu un exemple en ligne ?
@patdam - bonne question concrète. Voici le problème central : Le levier SRAM GX 11V est conçu pour un espacement 11 vitesses. Le dérailleur Eagle 90 est conçu pour un espacement 12 vitesses. Ces deux espacements ne sont pas compatibles - le câble tiré par clic du levier 11V ne correspond pas à ce que le Eagle 90 attend pour se déplacer d'un pignon à l'autre. Résultat : l'indexation sera systématiquement décalée et le barrel adjuster ne peut pas corriger un mauvais espacement, il décale juste tout le bloc.
Donc non, cette combinaison Eagle 90 + levier GX 11V + cassette 11V ne fonctionnerait pas correctement. Pour que ça marche, il faut choisir l'un ou l'autre :
Option A - rester en 11V • Dérailleur 11V compatible HG (Shimano XT/SLX/Deore 11V, ou SRAM GX 11V Eagle - le dérailleur, pas l'Eagle 90)
• Levier SRAM GX 11V ✓ • Cassette Sunrace 11V HG ✓
• Chaîne 11V ✓ Tout est cohérent, ça marchera.
Option B - passer en 12V pour garder l'Eagle 90 • Dérailleur Eagle 90 ✓
• Levier Eagle 90 (ou Eagle AXS compatible) - le levier 11V doit être remplacé • Cassette 12V XD ou XD-R
• Chaîne 12V Eagle La cassette Sunrace HG (corps Shimano) est incompatible avec un corps XD de toute façon, donc l'Option A est probablement le chemin le plus simple si tu veux utiliser cette cassette.
Je n'ai pas trouvé d'exemple en ligne de ce combo exact Eagle 90 + levier 11V qui fonctionne - et ça m'étonnerait d'en trouver, vu le désaccord d'espacement.
@patdam - good practical question. The core problem:
The SRAM GX 11-speed lever is designed for 11-speed spacing. The Eagle 90 derailleur is designed for 12-speed spacing. The cable pull per click from the 11-speed lever doesn't match what the Eagle 90 needs to step between cogs - the barrel adjuster can shift the whole thing up or down, but it can't fix a fundamental spacing mismatch.
So no - Eagle 90 + GX 11-speed lever + 11-speed cassette won't index properly. Pick one path:
Option A - stay 11-speed • 11-speed derailleur (Shimano XT/SLX/Deore 11V, or SRAM GX Eagle 11V - the derailleur, not the Eagle 90)
• SRAM GX 11V lever ✓ • Sunrace 11V HG cassette ✓
• 11V chain ✓ Everything matches - this works.
Option B - go 12-speed, keep the Eagle 90 • Eagle 90 derailleur ✓
• Eagle 90 (or compatible AXS) lever - the 11V lever needs replacing • 12-speed XD or XD-R cassette
• 12V Eagle chain Worth noting: your Sunrace HG cassette uses a Shimano-body freehub, which is incompatible with XD anyway - so Option A is almost certainly the simpler route if you want to use that cassette.
I haven't found any working example of Eagle 90 + 11-speed lever online, and the spacing mismatch is well-documented enough that I'd be surprised to.
    676K
