Rear Tyre Suggestion
Blakey
Mid Sussex, UK
I’m an intermediate rider. Ride mostly on loamy forest trails and very flinty South Downs hills. My rear tyre has shredded today (second wall rip in the last year). I had to bin it.
What should I replace it with? Any absolute no brainer options? I’d like one that will survive the flinty trails Tubeless.
Thanks!
I’m an intermediate rider. Ride mostly on loamy first trails and very flinty South Downs hills. My rear tyre has shredded today (second wall rip in the last year). I had to bin it.
Thanks!
Exactly what was the rear tyre that shredded?
Would have been a Maxxis Dissector.
Maxxis DHR2 in DD Casing is what you want. It's what I upgraded my PL Carbon Pro to. That or Schwalbe Albert Radial, Gravity Pro. The new Amflows are running this.
Agree - ordered a Magic Mary & Albert radials for when my Maxxis need changing (or start to slide in the mud too much).
no pneumatic MTB tyre will survive an argument with freshly broken flint
try and stay away from any freshly ploughed sections
Downhill rated tyres are your best bet
I've run light weight trail casings on the treacherous south downs for years & had exactly one sidewall puncture.
Yes, I know. I think I'm cursed. Had the Amflow for less than a year and had two in the same tyre - both very big, the last one big enough to make me throw the tyre away.
Again, anyone that knows, please can I ask if MAXXIS Minion DHR II is the right choice for a replacement?
Yes it's a perfectly good tyre just keep in mind it doesn't have a force field!
Kryptotal R soft. I have run the Shawlbe radials twice between 3 sets of Contii's. The DH casing is 150g heavier, have not had an issue with either in 3 Conti tyre sets. Enduro casing in my latest, just as good as DH.
Just received another set of Conti Krypts in enduro SS/S. Great tyres !
it's a classic tyre, however hard leans require a wee bit of faith, as there is a distinct gap between the centre and outer treads
also whilst it's pretty good at cleaning mud because of the large gaps - the areas in between are a bit more vulnerable.
something like a kryptotal (downhill) or an Eddy Current (Gravity) or an Albert (Gravity) have more grip/rubber on the ground
All are weighty (you can get the Schwalbe's in Radial if you want a bit more grip/compliance)
    673K
