A response from whyte
"""Thank you for your message and interest in Whyte Bikes!
Thanks for getting in touch. As the bikes are not in dealers yet, there is still a limited amount of hands-on setup information available at this stage.
As a guideline, the weight should be around 24–25kg.
The rear shock size is 230 x 62.5mm, and yes, a coil can be fitted with no problem."""
Going to make a spread sheet to see what could be changed to save weight. Would be nice to get a weight for the none evo version too.
Seems to be getting heavier and heavier, saw some wild predictions of 18kg at the start
