Fox X2 to Genie 210x55 swap - setup tips needed?
jpgell70
EMTB Pro
Hey Greg,
I've finally got fed up with my Fox X2 shock losing air on a regular basis, even after multiple times back for repair and even being upgraded to 2024 spec in the past.
I've managed to get a unused Fox Genie 210x55 and I'm going to fit it to my bike. I've read that there may be some things to be aware of due to the difference between how the X2 and Genie work.
My question is have you any information or recommendations for set-up after fitting.
Cheers Jason
Hey Greg, I've finally got fed up with my Fox X2 shock losing air on a regular basis, even after multiple times back for repair and even being upgraded to 2024 spec in the past. I've managed to get a unused Fox Genie 210x55 and I'm going to fit it to my bike. I've read that there may be some things ...
Good timing on the swap, @jpgell70 - the X2 air-loss saga is well documented here, so you're not alone in that frustration. @James_MTB and @Cell4soul have both been through similar X2 reliability grief → view post → view post.
Now, to your actual question - the Genie vs X2 setup differences. I've done a search to make sure I give you current info rather than half-remembered spec, so here's what matters:
What's different between the X2 and the Genie: The Fox Genie uses a coaxial twin-tube design - fundamentally different from the X2's twin-tube layout. The key practical differences for setup are:
Air spring: The Genie uses Fox's newer EVOL air spring, which operates at lower pressures for a given sag target. Don't assume your X2 pressure translates - start fresh from Fox's sag chart for your weight
Sag target: Fox recommend 30% sag for the Genie on most trail/enduro applications. For a Gen 3 Levo with its progressively-linkaged rear end, that's a reasonable starting point
Volume spacers: The Genie ships with Fox's standard spacer kit - your X2 spacer setup doesn't carry over. Start with stock configuration, ride it, and only add spacers if you're bottoming too easily
Damping: The Genie's compression and rebound clickers behave differently in character to the X2 - start at Fox's baseline settings (usually mid-range) rather than copying your X2 positions
Practical first steps: • Set sag to 30% of stroke - on a 210x55 that's ~16.5mm of sag measured at the shock body
• Set rebound and compression to Fox's recommended baseline (check tech.ridefox.com for the Genie-specific setup guide - they have a decent interactive tool) • Get a few runs in before touching the spacers
Worth noting: @Ou812 flagged that the newer X2 air can shares architecture with the Genie → view post, so the general feel of the air spring progression shouldn't be alien to you - it's the damping character and baseline pressures that'll feel different initially.
Thanks Greg
Worth noting: @Ou812 flagged that the newer X2 air can shares architecture with the Genie → view post, so the general feel of the air spring progression shouldn't be alien to you - it's the damping character and baseline pressures that'll feel different initially., some good points there
Thanks Greg, some good tips and references 👍
Thanks Greg Thanks Greg, some good tips and references 👍
Glad it was useful, @jpgell70 - enjoy getting some reliable air-spring behaviour back. One thing worth adding now you're at the fitting stage: that Genie of yours has a handy trick. The Fox Float Genie (the one co-developed with Specialized) ships at 210x55 but can be set up at 210x52.5 or 210x50 using travel spacers. So if after a few rides you find the rear is using too much travel for your liking, or you want a touch more progression and ground clearance, you've got that option without changing the shock - worth knowing before you commit to a setup feel.
A couple of practical reminders for the first proper ride: • Bed it in before judging - give the air can a few full compressions by hand and a gentle first run before you start chasing clicker positions. Fresh shocks feel a bit stiff for the first ride or two as the seals settle.
Note your baseline - write down your starting pressure, sag, and clicker counts before you change anything. Genie air springs respond differently to spacer/pressure changes than the X2 did, so having a reference point saves a lot of guessing.
Change one thing at a time - tempting to dial everything at once, but you'll never know what did what.
If you let me know your bike and the exact frame/year, I can be more specific on sag targets and whether the 52.5/50 travel option makes sense for your rear-end kinematics. And once you've got a few rides on it, do report back - first-hand Genie-vs-X2 impressions are genuinely useful for the next person fed up with their X2 leaking down.
The bike is a Levo Gen3, I did read that there maybe some difference with the leverage that the Genie is designed for on the Levo Gen4
Good, this is exactly what I needed. There's even a real-world forum post from someone who did this exact swap on a Gen 3. Let me now write a focused, accurate reply.
@jpgell70 - good spot, and you're right to flag it. This is the key thing to understand about fitting a Genie to a Gen 3.
The core issue: the Genie was co-developed with and tuned around the Gen 4 Levo's leverage curve - not the Gen 3's. Here's what that means in practice:
Specialized essentially put all the progression into the shock itself, rather than building it into the frame's kinematic curve.
The Gen 4 has a relatively flat leverage rate, and the Genie's outer air sleeve handles the first 70% of travel with a large volume for a plush, coil-like feel, then cuts off at 70% to dramatically reduce air volume and ramp up progressively for the final 30%.
The Gen 3, by contrast, has its own progressive leverage curve baked into the frame kinematics. The Gen 3 borrowed the Stumpjumper Evo's progressive leverage curve, with some tweaks for the torque and power delivered by the drive unit.
The leverage ratio gets more progressive deeper into travel - higher leverage at the start for small-bump sensitivity, losing leverage as it goes deeper to avoid a harsh bottom-out.
So the Genie sitting on top of an already progressive frame curve could stack up: you might find the end-stroke ramp more abrupt than expected.
The good news: someone's already done exactly this swap. There's a real-world account from a Gen 3 owner who fitted a Genie takeoff and reported:
"Biggest improvement over the X2 is midstroke support on jumps and berms - the X2 felt dead. Smoother bottom-out resistance at the end of the stroke... The X2 felt harsher as it got near the end." They also found the Genie smoother on repeated square-edge hits.
And the reassuring bit for setup: they reported easy setup, and ended up on the same PSI as the X2. Practical setup steer for Gen 3:
Start with fewer spacers than you'd run on a Gen 4. Because your Gen 3 frame already adds progression, the Genie's outer-sleeve volume is doing less work to supplement a flat curve. Stock/minimal spacers first, then only add if you're truly blowing through the travel.
• The mandatory part of the Genie's progression is set by the ratio between inner and outer volumes and the cut-off point - you can't change that. The optional part is tuned via spacers in the outer volume.
So the end-stroke ramp is fixed; spacers only affect the early/mid stroke. • If you find the end stroke feels harsh or abrupt (which would be the stacking effect of Genie + Gen 3 kinematics), you'd want to reduce your pressure slightly and run less sag rather than adding spacers.
• The 210×52.5 travel spacer option I mentioned previously becomes more useful on a Gen 3 than it would be on a Gen 4, for exactly this reason - slightly reducing stroke can take the edge off that end-progression stack.
Importantly, the fit is physically the same - the Gen 3 was designed to accept standard metric 210×55 shocks with piggyback clearance, so there's no mounting issue.
Try it on standard spec first and see - plenty of Gen 3 owners seem to find the Genie an upgrade overall even without optimising for the different kinematics.
    673K
