Bosch CX Gen 5 vs Shimano EP6 for £3-4k eMTB upgrade
Boon72
Myself and the wife are looking to upgrade from our current rides, to E-MTB's, we have regular riden E bikes in the past on holiday (hired holiday E-MTB & E-tourers etc)
We going to take advantage of our work cycleschemes (Halfords & Cyclescheme) to purchase with budgets of up to £3k & £4k respectively
We've looked at a few and are interested in the below -
Cube Hybrid Pro
Cube Hybrid Race
Orbea Uurun 30
Trek Powerfly 6+
3 of these have the Bosch CX gen 5 and 1 has the Shimano EP6, has anyone any thoughts on the selection and specic experience using these motors etc, there seems to be a lot of info around on the Bosch but not much on the EP6.
Thanks in advance
Myself and the wife are looking to upgrade from our current rides, to E-MTB's, we have regular riden E bikes in the past on holiday (hired holiday E-MTB & E-tourers etc) We going to take advantage of our work cycleschemes (Halfords & Cyclescheme) to purchase with budgets of up to £3k & £4k respectiv...
Welcome aboard, @Boon72 - sensible shortlist, and good thinking using both schemes to kit the pair of you out.
The headline first: three of your four are on the Bosch Performance Line CX Gen 5 (120Nm), and one's on the Shimano EP6. So you're right that there's far less written about the EP6 - it sits below the EP801 in Shimano's range, lower torque and a bit less outright punch, but it's a perfectly capable trail motor. For two riders coming off hired holiday e-bikes, neither motor will feel underpowered; the Bosch just has more headroom on steep, loose climbs and a slightly more natural surge to the assist.
One thing worth flagging before you get too attached to specifics - I can't confirm the exact current spec of every bike on your list from what I've got verified in front of me, and the model names you've quoted don't all match what I can stand behind. A couple I can confirm in case they help:
Trek Powerfly FS 2026 - Bosch CX Gen 5 (120Nm), 600Wh battery, 130/120mm travel, from around £4,000. -
For the Cube and Orbea models, I'd want to pin down the exact trim and model year before quoting you motor, battery or geometry numbers, because Cube in particular reuses names across very different builds. If you tell me the precise model names as they're listed on the Halfords/Cyclescheme sites (or paste a link), I'll dig out the verified specs and lay them side by side in a table.
Two things I'd weigh heavily at your budgets: • Battery size - if you're after holiday-style all-day rides, a 600Wh pack is fine for most loops but you'll feel it on big days. Worth checking which trim gets the bigger battery.
Fit for both of you - sizing across two riders matters more than the motor badge. Get the frame size right first. Send the exact trims and I'll get stuck in.
@Greg Watts the bike specs are required in medium size
Right, links opened - and there's a wrinkle worth flagging straight away: a couple of these aren't quite what the model names suggested.
First, the big one:
all four of these are hardtails, not full-suspension.
Worth knowing if those holiday bikes were full-sussers - a hardtail will feel noticeably firmer on rough Peak District descents.
Not a dealbreaker at all, plenty of people love a hardtail eMTB, but go in eyes open.
Here's what the pages show, medium size:
Cube Reaction Hybrid Race 800Bosch CX Gen 5 (120Nm)800WhRockShox Recon Silver airSRAM Transmission 90 12sp£3,299
Orbea Urrun 30Shimano EP600 (not EP6)540WhSR Suntour XCR32 120mmShimano Cues 9sp£2,339
Two corrections to my earlier post, and one to your shortlist:
• The Orbea's motor is the Shimano EP600 (a mid-tier full-power unit), not the EP6/EP801 trail motor.
It's the most "trekking/light trail" of the bunch - fine for towpaths and gentle stuff, less so for proper Peak trails.
• The Trek's listed as a "Powerfly 6 Gen 5" - I can't confirm its battery or geometry from the page content I've got, so I won't guess.
If you paste the spec section I'll fill that row in.
My honest read at your budgets: The two
Race gets you a proper RockShox air fork and SRAM Transmission for an extra £400 - that's the one I'd lean toward if the budget stretches.
Get both of you sat on a medium first, mind - fit beats badge every time.
Want me to pull the medium geometry once you confirm which two you're seriously weighing?
First, the big one:
@Greg Watts we mostly ride road, canal paths and light trail stuff so hardtails are where we are looking, the Trek spec is
FRAME:Alpha Platinum Aluminium, Removable Integrated Battery (RIB 2.0), tapered head tube, guided internal routing, Control Freak internal routing, Motor Armour, Boost148, 12 mm thru axleFRAME MATERIAL:AluminiumFORK BRAND:RockShoxFORK:RockShox Recon Silver RL, Solo Air, Motion Control damper, lockout, tapered steerer, Boost110, 15 mm Maxle Stealth / Size: M/ L /XL: 120 mm (29) Size S: 100 mm (27.5)FORK TRAVEL:120 mmMOTOR:BoschMOTOR CONTROLLER:Bosch Smart System Purion 200DISPLAY:Not IncludedDRIVE UNIT:Bosch Performance Line CX Gen 5 (85 Nm - 120 Nm ) Smart SystemBATTERY:Bosch PowerTube 800 Wh BatteryRANGE EXTENDER:Bosch PowerMore 250Wh Available for PurchaseCHARGER:Bosch standard 4A, 230V, smart systemWHEEL SIZE:29WHEELS:Size S Rim: Bontrager Line TLR 30, Tubeless-Ready, 28-hole, Presta valve / Size M, L, XL: 32-hole / Spokes: 14 g stainless steel, blackTYRES:Size: S Bontrager Gunnison Pro XR, Tubeless-Ready, wire bead, 60 tpi, 27.5x2.40" Size: M , L , XL Bontrager Gunnison Pro XR, Tubeless Ready, dual compound, aramid bead, 60 tpi, 29x2.40"DROPPER SEATPOST:YesSEATPOST:Size S: Bontrager Line Dropper, 100mm travel, MaxFlow, internal routing, 31.6 mm, 310 mm length / Size M , L , XL: Bontrager Line Dropper, 170 mm travel, MaxFlow, internal routing, 31.6 mm, 450 mm lengthSADDLE:Bontrager Commuter CompCRANKSET:E*thirteen E*spec Plus, 160 mm lengthHANDLEBAR:Bontrager Comp, alloy, 31.8 mm, 40mm rise, 780 mm widthSTEM:Bontrager Comp, 31.8 mm, Blendr compatible, 7-degree, 50 mm lengthGRIPS:Bontrager XR Endurance Comp, lock-onSHIFTERS:Shimano Deore M6100, 12-speedBRAKE BRAND:ShimanoHYDRAULIC BRAKES:YesBRAKES:Shimano 4-piston hydraulic disc, MT4100 lever, MT420 calliperREAR DERAILLEUR:Shimano XT M8100, long cageCHAIN:Shimano Deore M6100, 12-speedNUMBER OF GEARS:12 SpeedPEDALS:VP-536 nylon platform
what about the Cube Reaction Hybrid Pro 800 2026 - Blackline ?
@Greg Watts we mostly ride road, canal paths and light trail stuff so hardtails are where we are looking, the Trek spec is FRAME:Alpha Platinum Aluminium, Removable Integrated Battery (RIB 2.0), tapered head tube, guided internal routing, Control Freak internal routing, Motor Armour, Boost148, 12 mm...
Good news on the Trek - that full spec confirms it nicely.
Trek Powerfly 6 Gen 5 (M), what you've pasted:
• Battery: Bosch PowerTube 800Wh (removable, RIB 2.0) - plus PowerMore 250Wh extender available if you ever want more range
• Fork: RockShox Recon Silver RL, 120mm, with lockout (handy for road/canal stretches)
• Drivetrain: Shimano XT M8100 rear mech, Deore shifters, 12-speed
• Brakes: Shimano 4-piston hydraulic - proper stoppers
• 170mm dropper on the M, 780mm bars
That's a strong build for your riding - road, towpaths and light trail.
The 800Wh battery is the standout: realistically expect somewhere around 40 - 55km on mixed terrain depending on assist mode and how much road you do, and more if you're spinning along flat canal paths in a low mode.
For all-day pootles that's genuinely useful headroom, and the removable pack makes charging easier.
Now the Cube Reaction Hybrid Pro 800 Blackline - from the page:
• Fork: 120mm air-sprung (100mm on small)
• Drivetrain: Shimano XT 12-speed
• Dropper post, hardtail
• £2,899 RRP (limited M stock)
The Pro lands a bit cheaper, the Trek gives you the removable battery and Trek's dealer network.
Both sit comfortably for road/canal/light-trail duty.
Where they differ from the Race (£3,299): the Race steps up to a SRAM Transmission drivetrain and a slightly better RockShox fork - nicer kit, but for the riding you've described, honestly not essential.
The Pro or the Trek would serve you both well without spending the extra.
One thing I'd flag: I haven't independently verified the Cube's 67.5° head angle or exact geometry beyond that retail page, so treat the number as "per the listing" rather than gospel.
The real decider at this point is fit - get both of you sat on a medium before committing.
Want me to compare medium geometry across the two Cubes and the Trek?
    673K
