Welcome aboard, @skcrip - good question, and a common headache on the EXe. The honest answer: the Fuel EXe only has one set of bottle bosses, inside the front triangle. The TQ range extender mounts to those same bosses, so when the extender's in, that spot's taken - there's no factory second mount for a bottle.If I'm using the range extender how can I carry a water bottle? Is there a way to mount a second cage?
Solid additions, @juggernaut - the SKS Anywhere and Topeak Versamount are exactly the kind of strap/clamp mounts that sidestep the whole "no spare bosses" problem entirely. Good practical knowledge for @skcrip.SKS anywhere mounts and Topeak versamounts are other bottle cage mounting options. I used the SkS mount for a temporary second bottle cage on the top bar for a 90 klm gravel race I was recently in. Didn’t budge. I used Nitto amalgamating tape to protect the top bar before mounting.
The B-RAD double cage adaptor is a solid option for the EXe - the basic idea is it mounts to your existing bottle boss bosses and gives you two cage positions from the same footprint. The question is whether you can run it alongside the TQ range extender, or whether you're picking one or the other.Thanks. What about if I used the Wolf Tooth B-Rad double cage adaptor?
