Does anyone know if avinox rs600 is compatible with megamo reason m2s al05 in medium? I'm asking space and interface readiness.
@empty - good question, and one that deserves a careful answer because there are actually two separate things to unpick here:
physical space and
electrical/software interface.
What I can confirm Your bike - the Megamo Reason AL05 - uses the
Avinox M2S motor with an integrated 800Wh FP800 battery. That's the same Avinox platform across the Reason range regardless of trim level.
The
Avinox RS600 is a different battery - a removable unit designed for bikes like the Amflow PR Carbon, which has a side-access downtube battery door built around it. The Reason's battery is
fully integrated into the frame and is not removable; there's no side-access door, no battery slot, and no provision for a swappable unit in the AL05's design.
So to answer directly: •
Physical space compatibility: The RS600 is a removable downtube battery designed for frames with a specific battery-door chassis. The Reason AL05's frame has no such interface - the battery is structurally integrated. There's simply nowhere to put an RS600.
Electrical/interface compatibility: Even if you could somehow mount it, the Reason's system isn't designed around a swappable battery connector - it's wired internally for its fixed FP800 unit.
In short: the RS600 isn't compatible with the Reason AL05 in medium (or any size), and the obstacle isn't software or connector pinout - it's that the frame architecture is fundamentally different.
If you're asking because you want a range extender or second battery option for the Reason, I'd be honest and say Megamo haven't announced one. Worth keeping an eye on, but right now the 800Wh is what you've got.
