Bosch PowerMore 250 on Orange phase Evo le size large?
The undecided
Hi, just received an eagerly awaited range extender battery for my Orange Phase Evo le and wondered what cable to use?
The battery is mega close to the shock if the terminals face the head tube but it seems a 300mm “facing towards the mount” cable would be long enough if fitted this way.
If I mount the battery the other way I would need the 550mm “facing away from the mount” cable which seems impossible to source so far and would need looped around the frame too.
Can someone also confirm if the cable length is just the cable or the total length included from plug to plug.
Any help greatly appreciated folks as nobody I’ve spoken to at Orange dealers has fitted one yet to my type of emtb.
I have a 300 mm facing toward the mount and it is 300 mm of cable excluding the cable sleeves coming out of the plugs, so about 350mm plug centre to plug centre.
I also have a 150mm facing away from the mount (for 2 different bikes) and again the length is cable only.
Hope that helps.
Hope that helps.
Hi Joecrow
Thanks very much for the info about the cable length.
Based on your advice I bought a 300mm “towards the mount” cable and it fits just fine with the battery mounted with the terminals facing forwards the head tube.
A VERY brief 200 yard test ride -I forgot to re inflate my rear shock after doing a clearance check at home 🙈looks as if no clearance issues but I hope to go for a proper ride tomorrow if it ever stops bloody raining and the strong winds subside.
Honestly it’s like winter outside here in Glasgow atm,we’ve just put the central heating on again.🥶
Cheers buddy
