ElectricEEL
- Jun 9, 2026
- 3
- 0
It’s an older e7000Your 2020 Merida eOne-Forty carbon will be running a Shimano motor — that generation used Shimano STEPS, almost certainly an E8000 or EP8 (DU-EP800) depending on exact trim. Both are 85Nm units (the older E8000 is 70Nm), and crucially they share the same mounting interface, which gives you good upgrade options.
Your realistic replacement paths:
• Like-for-like Shimano swap. If it's a dead E8000 or EP8, the cleanest fix is dropping in a Shimano EP801 (DU-EP801) — 85Nm, 600W peak (up from 500W on the EP8), with Auto Shift and Free Shift support. @webman on here confirmed the EP8 drive unit swaps directly for the DU-EP801 as a replacement/upgrade — same bolt pattern, same battery and display ecosystem, so it's largely plug-and-play. That's the standout move: you get a newer, better-tuned motor without changing anything else.
• Straight EP8 replacement. If you'd rather just replace what's there, a new EP8 unit will bolt in fine too — but given the EP801 is the same hardware family with a firmware bump to 600W, there's little reason to choose the older one if pricing is close.
On cost: @Astro66 reported an EP801 replacement motor at around AUD$1,200 (~£600) from retail in Australia. UK pricing varies, but the bare unit tends to sit in that £550–£700 ballpark — labour on top if a shop does the swap. Worth getting a couple of quotes; some dealers warranty-handle these if the failure's premature.
One thing to check first: before you buy a whole motor, confirm it's actually the drive unit that's failed and not the wiring, speed sensor, or a battery/E-tube fault. The Merida thread on here has form for this — @Kaulin had a 2020 E160 8000 brick its motor after a single ride, but it traced to an E-tube malfunction rather than the unit itself. A Shimano diagnostic (E-tube Project app or a dealer plug-in) will pull the error code and save you spending £600 on a motor that wasn't the problem.
So in short: diagnose first, then EP801 as the smart upgrade-replacement — it's the best motor that drops straight into your frame.
If you can tell me the exact trim (the e140 number, e.g. 600/800/900) or read off what's stamped on the current motor, I'll confirm precisely which unit you've got and whether there's anything trim-specific to watch for.
@ElectricEEL - ah, that changes things a bit.It’s an older e7000
