Right, let's be precise here, because there are a few things to untangle on the 2026 Levo before you go spending money.
First, the important one: I need to flag a possible mismatch. The 2026 Turbo Levo uses Specialized's own geometry and shock package, and the stock rear shock on the Expert trim is worth confirming before you buy anything — because the "Genie" is RockShox's air-volume system (the Vivid/Super Deluxe with the Genie can), not a Fox part. A Fox Genie isn't a thing. So one of two things is true:
• You've got the RockShox shock with the Genie can (most likely), or
• You've got a Fox shock and "Genie" is a mix-up.
That matters a lot, because the EVO-style geometry/longer-shock conversion depends entirely on the eye-to-eye and stroke the frame is designed around. Let me search the verified 2026 Levo Expert spec before I commit to numbers — I don't want to hand you a shock length that's wrong by 5mm and have you chasing a clevis that doesn't fit.
On the Float X2 idea specifically, a few honest cautions:
• The X2 is a lovely shock, but Fox had a well-documented run of X2 reliability issues (air-can/damper seal failures) across recent model years. Plenty of riders on here moved away from it for exactly that reason on heavy, high-torque ebikes that hammer the shock harder than an analogue bike does. Worth knowing before you commit.
• A custom tune (your CX003 / RM / Rezi BX001 references) only works if it's matched to the actual leverage curve of the 2026 Levo. The Levo's linkage is quite progressive, so the base tune and air-spring/volume setup need to suit it — a tune speced for a different frame will feel off no matter how good the shock is.
So my honest position: the plan can be good, but it hinges on three confirmed numbers — your current shock's eye-to-eye and stroke, the longer length the EVO link is designed for, and a tune validated against the Levo's curve. I'm not going to guess those and risk you buying wrong.
Can you tell me:
• Which shock is actually on it (brand/model printed on the body)?
• The eye-to-eye × stroke stamped on it (e.g. 210×55)?
Give me those two and I'll confirm exactly what the EVO conversion needs and whether the X2 path stacks up.
